![]() Join Date: Nov 2010
Grille Surround Differences
Im working on getting a front clip back on my 62 burb, and it came with a real nice grille surround with a 64-66 grille on it which I assume it what year the surround came from..But is there any difference in how a 62 grille would mount into the 64-66 grille surround? Or will it bolt up? Havent really dealt with early 60-63 stuff. Any help would be great.
Re: Grille Surround Differences
I believe you will have to drill a couple of holes in the surround for the 62 grille, otherwise it should be the same.
1961 crewcab
... and the 63-66 surround has big notches for the frame horns, which the 60-62 does not.
it will still fit, but you will probably be able to see the holes over the bumper...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Okay. I dont have a 62 grille so Ill probably just put this one on for now just to have it on there
