Old 10-21-2014, 10:25 PM   #1
NJ C10 Guy
2.73 rear end question
Hey guys, quick question. I have a stock 2.73 rear end in my 86 stepside now and I'm looking to swap out for a 3.73. Just to be certain, the stock rear in my truck is a 10-bolt, 8.5", 30 spline, 3 series carrier, correct? I'm looking at the Motive Gear gm10-373 kit and I want to make sure it will work.
http://m.summitracing.com/parts/mgr-gm10-373
I had a guy I called to get a quote from tell me that I'd need a new carrier. I was also quoted me $600 for labor only on the install, which is a little insane IMO. Thanks in advance for the help.
NJ C10 Guy is offline   Reply With Quote
Old 10-22-2014, 06:44 AM   #2
Jake Wade
Jake Wade's Avatar
Re: 2.73 rear end question
Those will work fine with your carrier. 2.73 and up is one style carrier, anything below 2.73 takes another style. You are good to go! and yes, $600 is steep for just labor, $250-$300 is the norm.
Jake Wade is offline   Reply With Quote
Old 10-22-2014, 06:45 AM   #3
D13
D13's Avatar
A stock 86 wil be 28 spline, 30 splines came later. Carriers split, 3 series 3.43 and higher, 4 series 3.73 down. So yes you would need would need a carrier, assuming stock type gear sets, although you can get 3.73's for a 3 series carrier IIRC. At that point, you should put in new bearings. The labor cost seems in line with what others have been quoted for a complete redo.
Be certain how many splines your axles have first! Otherwise you'll need axles out of a later K5 or burb.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 10-22-2014, 10:44 AM   #4
Jake Wade
Jake Wade's Avatar
The gears in the link you provided will work fine on your carrier if it is 2.73 now, trust me.
Old 10-22-2014, 03:05 PM   #5
Rich84
Rich84's Avatar
30 Splines are in the 88 and up.
Rich84 is offline   Reply With Quote
Old 10-22-2014, 04:45 PM   #6
NJ C10 Guy
I placed a call to motive gear today. Figured I'd call the source. If they make the part they should know what it fits. The guy on the phone confirmed it would fit without having to switch the carrier.
