Old 10-21-2014, 11:27 PM   #1
Handmedown
Handmedown's Avatar
Pitman arm
Is this much gap normal? Or is my steering getting ready to come apart?
Handmedown is offline   Reply With Quote
Old 10-21-2014, 11:35 PM   #2
mitchell72
mitchell72's Avatar
Re: Pitman arm
It looks about the dame as mine. I just did my front end. You will find when you take it off, and then put it back on, it will only go so far.
mitchell72 is offline   Reply With Quote
Old 10-22-2014, 07:36 AM   #3
JointTech
JointTech's Avatar
Re: Pitman arm
looks like my old and new one.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 10-22-2014, 09:21 AM   #4
Grumpy old man
Grumpy old man's Avatar
Re: Pitman arm
Get a pressure washer in there to clean it up and you will see it's a tapered splined shaft and does not allow the pitman arm to slide all the way down to the steering box ,Throw a wrench on it and tighten it up ...problem solved ....
Grumpy old man is offline   Reply With Quote
Old 10-22-2014, 08:51 PM   #5
Craftsmen
Re: Pitman arm
It looks normal to me, I just changed out my steering gearbox yesterday. It takes a 1-5/16" socket and after tight with the lock washer the splined shaft sticks out just a little past the end of the nut.
Craftsmen is offline   Reply With Quote
Old 10-22-2014, 10:15 PM   #6
sprint_9
sprint_9's Avatar
Re: Pitman arm
Looks fine, and if its factory I wouldn't worry. There is a lock washer on the nut and it is a tapered fit as mentioned.
If you are unsure and want to check it, the nut should be tightened to about 185 ft-lbs for proper seating of the pitman arm on the tapered splines. I just put one on my S-10 and it is almost exactly the same setup that is on my C-10
sprint_9 is offline   Reply With Quote
