Old 08-15-2003, 09:09 AM   #1
beaterC10
Question How do you indentify a 400SB
I posted the same question on the drivetrain board. Hoping someone has the answer.
Is there a quick a dirty way to identify a SB400 that is still in the truck without the gymnastics involved trying to read the casting numbers on the back of the block.
I was hoping the balancer might be the tipoff like it is on a 305. I thought some of the early 400's had 3 freeze plugs per side instead of the normal 2.
The engine is supposed to be a '75 vintage that runs but has a miss. The guy thinks it is bad valves, but I guess it could also be a sloppy timing chain, worn out cam, vacuum leak etc.
Any idea what a complete 400 is worth. Probably more than a 305 and less than a 454.
beaterC10 is offline   Reply With Quote
Old 08-15-2003, 09:18 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You're on the right track, with the balancer and freeze plugs.
I read in Hot Rod awhile back that there had only been a very few 400 SB found that didn't have 3 freeze plugs on the side of the block. That's the safest bet is to count the plugs.
Old 08-15-2003, 10:53 AM   #3
beaterC10
Do you know what the difference is between a 350 and 400 balancer? I know the 305 is smaller in diameter and thicker than a 350, but I dont' know the differences between the 350 and 400.
Old 08-15-2003, 11:11 AM   #4
Blazer1970
Blazer1970's Avatar
Since the 400 is externally balanced, the balancer has a notch missing out of the OD. It is an 8 inch balancer, but you will see (or feel if it is on the bottom at the time), the notch that is cut out for balance.
Personally, I would go by the block ID number and/or casting number. A '75 400 should be CHS, CSH, CSM, CSR, CSS, CST, CTB, CTL, CTM, CTR, CTU, CTW, TLD, TLH, TLR, TLS, TLT, or TLU (Cs are car engines, Ts are truck engines). The casting number should be 3951509, 3030817 or 330817.
If you know what to look for, the 400 block casting can be quickly recognized because the outside of the block has bulges around each cylinder bore that are not present on any other small block casting.
Blazer1970 is offline   Reply With Quote
Old 08-15-2003, 12:09 PM   #5
1FaastC10
1FaastC10's Avatar
both the 305 and 350 bablancers are zero balanced, so in reality someone could've put a 350 balancer on a 305, or a 305 balancer on a 350. should always go by the casting numbers to tell you for sure. they're not that hard to get to.
1FaastC10 is offline   Reply With Quote
Old 08-15-2003, 12:32 PM   #6
beaterC10
Thumbs up
Thaks for the help. The casting numbers are on the rear near the bellhousing and ID number is on the front passneger side near the intake, correct?
Old 08-15-2003, 12:38 PM   #7
Blazer1970
Blazer1970's Avatar
Yup
Old 08-15-2003, 04:18 PM   #8
jimfulco
Don't the 400's have 3 freeze plug bosses on each side?
jimfulco is offline   Reply With Quote
Old 08-15-2003, 04:48 PM   #9
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
The 400 in my 77 Blazer Chalet only has 2 freeze plugs 1 on each side.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 08-15-2003, 06:01 PM   #10
jimfulco
But is the boss there for a third one?
Old 08-15-2003, 08:10 PM   #11
82 Silverado 4X
Genuine Chevrolet
There is no boss for the 3rd freeze plug on my block. It's casting number is 3951509 and the stamping suffix is TLS. I had the oil pan off to change the oil pan gasket in 94 and it's only a 2 bolt main. My neighbor bought it new in 77 and it has only 54,000 original miles.
George
Old 08-15-2003, 08:54 PM   #12
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
the best and easiest way is to start the engine, and crawl under the engine and look up at the backside of the harmonic balancer.. it will look really wobbly and/or out of balance due to the huge counterweight void.. then you can kill the engine and see it a little easier if you didnt know what to look for.
mike
mike reeh is offline   Reply With Quote
