10-22-2014, 08:39 PM | #1 |
lowering a burb--static drop
when lowering a burb with springs do you use the standard truck lowering springs for trucks or the heavy duty ones from cpp. if you use truck springs how does it ride? aaaaaaaaaaand if you use the heavy duty ones does it seem like a better ride/ thanks
10-23-2014, 06:35 AM | #2 |
Re: lowering a burb--static drop
I used CPP regular truck springs and they were too light. The Sub never sat right. Tried a second set with the same result. Ended up using air bags. Nice ride and easy to adjust height.
65 burb On the road Mar 26th Finally |
10-23-2014, 10:33 AM | #3 |
Never Ending Projects
I bought the CPP HD 4" drop springs but sadly I have not had the panel on the road. They are thicker than the original springs so my guess is a higher spring rate. Wish I had more input to offer.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
10-23-2014, 06:52 PM | #4 |
Chevy addict
Not to hijack the thread but I am also looking to static drop the back of my Burb. I also will be carrying about 300 pounds occasionally. I think I will end up with bags inside the coils. Does anyone have experience with this set up.
10-25-2014, 06:54 PM | #5 |
thanks i might look into putting bags on the back. Lucifer do you just have shrader valves?
10-31-2014, 09:12 AM | #6 |
Yes just schraders. Make sure you get compression fittings, The push together stuff is problematic I have several leaks with the push together stuff and no problems with the compression type.
11-01-2014, 12:21 AM | #7 |
We replaced the stock springs with CPP HD 4" drop spings...way too soft/low for our taste...would bottom out with one person on the rear bumper. We swapped out the CPP drop springs for some LMC, HD, progressive rate, 3/4T, springs...we like these better (stock, LMC, and CPP together in that order in the pic) Gives the burb the rake we were looking for and will handle people/loads much better.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
11-01-2014, 06:38 PM | #8 |
so your burb sits stock in back or does the 3/4 springs make it higher? do you still have the cpp springs? thanbks
11-04-2014, 05:59 PM | #9 | |
For what its worth, this is a pic of how it currently sits with 2.5" drop spindles and a 1.25" drop block in back...
03-09-2016, 12:53 AM | #10 | |
But Found Her 25yrs Later!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
03-09-2016, 01:25 AM | #11 |
yes, dropped right in.
03-09-2016, 01:26 AM | #12 |
