10-23-2014, 09:15 AM | #1 |
Carb trouble
I recently made the mistake of putting a Edelbrock carb on my 71. I heard all the bullcrap about these carbs, but it was free. I ran it about three months before finally putting the old q-jet back on. It's running better, but it is getting hot now. I am at a loss as what is causing this. Thanks for any help.
10-23-2014, 09:32 AM | #2 |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Re: Carb trouble
Not the carb. Try a new thermostat and flush the cooling system for starters..
10-23-2014, 10:59 AM | #3 |
Re: Carb trouble
I like edelbrocks. You need to clean it if you got it used though, like with a carb dip. Then adjust the floats, idle speed and mixture. I added a phenolic spacer to mine after having some trouble with it boiling the gas in the carb and causing vapor lock! Settled it right down and starts right up now.
1968 LWB C20 / AC / Wood Bed |
10-23-2014, 11:46 AM | #4 |
Re: Carb trouble
yeah i been running a 1406 Edelbrock for a while now, the QJet that came with my truck was in need of a rebuild and i just swapped it out with the Edelbrock.
it's runs great, the only issue is hot starts. I've just ordered a 1" phenolic spacer and I have a fuel pressure regulator with an inline fuel pressure gauge. According to what I've read, if I get the pressure to about 5-5.5 PSI my problems should go away! Fingers crossed!!
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
10-23-2014, 12:52 PM | #5 |
US Army Veteran
Re: Carb trouble
Edelbrock carbs will boil fuel in the bowls after turning the engine off, making a restart take longer because as you pump, the fuel bowls refill. Whether it's a stop at the store for a few minutes, then coming back out to restart, or at the end of the day, then coming out in the morning.
Mornings, I would have to go through a process of three long starts and pumping the pedal to get started. After reading on the forum here (via google link below) about the Edelbrock 9266 heat spacer (for RPM intakes): https://www.google.com/#q=site:67-72...rock+9266+heat Picked up the #9266 heat spacer from my local Oreilly's along with a Mr. Gasket 1406 gasket (one below the spacer, one above the spacer for carb to sit on). Truck now starts on first try. No more hard/long starts while fuel gets back into the bowls. Hope that helps.
1972 C10 Highlander - The making of a daily driver |
