Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-23-2014, 10:37 AM   #1
chevy_mike
Never Ending Projects
chevy_mike's Avatar
3M molding tape to install rear door seals?
Hi all,
I have new seals for the rear doors on the panel. These are to be glued on, which can be a PITA and messy. I was thinking about the 3M molding tape. This is the thin stuff used on late model cars/trucks to hold trim moldings on the side of the vehicle. I was thinking I could apply the tape to the door and then stick the rubber seals to that. It would make for a clean and simple install and having tried to removed this stuff before, it seems to stick really well.
Has anyone else ever tried this method?
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-27-2014, 06:24 PM   #2
chevy_mike
chevy_mike's Avatar
Re: 3M molding tape to install rear door seals?
So I take it, no one has tried this...
Old 10-27-2014, 11:29 PM   #3
jweb
jweb's Avatar
I have never tried this but it looks like 3M tape is on the Steele rubber peel n stick products.
http://www.steelerubber.com/peel-n-stick-extrusions
I would try a test piece, let it sit for a few days then pull it apart to see what fails first. I hope this helps
jweb is offline   Reply With Quote
Old 10-28-2014, 10:56 AM   #4
chevy_mike
chevy_mike's Avatar
Cool, good call. Didn't know they offered those.
Old 10-29-2014, 10:18 AM   #5
rossboss
rossboss's Avatar
The seals should insert in the hinge hole and stay without glue. So why are you using glue, I must of missed something.
rossboss is offline   Reply With Quote
Old 10-29-2014, 10:44 AM   #6
chevy_mike
chevy_mike's Avatar
I think you are talking about the external hinge seal. I am talking about the seal that goes around the whole door, that seals to the body. These are normally glued on and I want to do it with less mess and hassle, hence trying to use the tape.
Old 10-29-2014, 11:50 AM   #7
rossboss
rossboss's Avatar
ok, I misunderstood your question. I was talking about the hinge seals.
