Old 10-23-2014, 11:52 AM   #1
Critter
Future TOTM Winner
Critter's Avatar
Help me ID this dana 44 axle please
I'm having some trouble figuring out what this axle came from. Its a d44 rear, 6 lug that is currently under a 66 GMC 1/2 ton 2wd. However from the terrible welds holding the spring perches to the tubes, I can tell it isn't original to the truck.
I have already replaced the cover gasket and all the brake components (shoes, springs, brake cylinders, etc). All of these components where ordered for a 66 GMC 1/2t 2wd and they were identical to what I pulled off. The difference became apparent when I went to put the new drums on. They aren't as wide overall. The actual shoe friction surface is the same width between the two (the shoes are 11"x2") but the original drums have an offset of about 0.75" that increases the distance from the shoes to the axle flange. The replacement drums I bought are flat across the front.
Like these pics...
This axle has a width of 61.5" from wheel mount surface to wheel mount surface. I cannot think of anything from GM that was this wide with a d44. The drum from napa lists a "height" of 3", the one that came off the truck is about 3.5". I've checked 67-70 dimensions and 4x4s and whatnot but no d44s have a drums like these. Where am I going wrong??? I'm sure its something obvious.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 10-23-2014, 12:25 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: Help me ID this dana 44 axle please
To find out what your dana originally came out of you need to locate the BOM number (bill of materials)
this should help you to locate it.
http://www.differentials.com/technic...identification
This should help you identify what your axle was in originally in.
http://www2.dana.com/expertforms/deabill.aspx
Livrat is offline   Reply With Quote
Old 10-23-2014, 01:12 PM   #3
Critter
Future TOTM Winner
Critter's Avatar
I'm not seeing any of those, the only number I could find was out by the pass spring perch, looks like
N45B2
Do those bump stops help identify it?
Old 10-23-2014, 01:12 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
I'm still scraping away looking for numbers...
