Sub, rear A.C. hose routing
Mario72 asked for these pics and I thought they might be helpful to anyone else doing a rear A.C. conversion so here they are. First pic is where they enter the cab below the dead door [driver side inner rocker], second is from inside the dead door to rear 1/4 panel and third is where they exit the roof/rear pillar to connect to the fan/blower unit.
Re: Sub, rear A.C. hose routing
Thanks for posting the pictures. I will get the money out to you this weekend.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Ttt for hose routing in a suburban
here's the overall routing
I would still like to see where the lines cross under the truck. Are the lines run on top of the trailing arm cross member ?
Mario, I will take some pics of the hose routing for you. I still have both 72 'Burbs w/ rear A.C. in my yard and both are trailing arm.
![]() Join Date: Mar 2012
This is a 70 Suburban 4x4.
You can see the 3 original clamps that hold the hoses to the bottom of the floor. |
2WD Suburban? My 4WD is slightly different. The hoses take a more right angle approach across the bottom above the transfer case.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
x2
