Old 10-23-2014, 06:03 PM   #1
AirSpeed
AirSpeed's Avatar
Looking for numbers on my 350, none there!
Just pulled my 350 and can't find a numer anywhere on it, it has no numbers in any of the traditional spots, any ideas what's going on?
AirSpeed is offline   Reply With Quote
Old 10-23-2014, 06:07 PM   #2
geezer#99
geezer#99's Avatar
Re: Looking for numbers on my 350, none there!
It was likely decked but should have the casting number behind the drivers head.
Old 10-23-2014, 07:16 PM   #3
factorystock
factorystock's Avatar
Originally a GMC engine?
factorystock is offline   Reply With Quote
Old 10-23-2014, 08:38 PM   #4
michael bustamante
michael bustamante's Avatar
Is it the original motor?
1967custom
michael bustamante is offline   Reply With Quote
Old 10-23-2014, 10:57 PM   #5
AirSpeed
AirSpeed's Avatar
I don't know, it has newer exhaust manifolds. There's not a number on it anywhere. I'm sure it has been decked and that took the numbers off the front but there's not another number on it anywhere, the only markings are the date code clock on the drive side rear of the block and "GM" to the left of it. I see a couple of areas where numbers are supposed to be but not a single number.
Old 10-23-2014, 10:58 PM   #6
AirSpeed
AirSpeed's Avatar
Nothing there except "GM" and the date code clock. No other numbers anywhere.
Old 10-24-2014, 04:32 AM   #7
mechanicalman
Later model engines have the casting number towards the top of the bell housing flange, like an 880 vortec or slightly earlier roller compatible block.
You also might find the last three numbers of the casting number on the side of the block above the pan rail.
Is the block smoother out all over? The PO may have wanted to make it pretty.
mechanicalman is offline   Reply With Quote
Old 10-24-2014, 02:49 PM   #8
AirSpeed
AirSpeed's Avatar
It hasn't been cleaned up, still see all the casting pits. No numbers on the cast in tags, they're all blank!
