10-23-2014, 08:20 PM | #1 |
Cowl gasket placement?
Bought a new rubber piece for the end of the cowl that seals the hood. Can't seem to get the hood to close easily with it on.
Does anyone have a pic of one in place or any advice on getting it right? Thanks |
10-23-2014, 08:29 PM | #2 |
Re: Cowl gasket placement?
project: "my happy mess" |
10-23-2014, 08:33 PM | #3 |
Should it go down to bottom of cowl?
I have the placement right but maybe I made it go too wide across...?? |
10-23-2014, 08:39 PM | #4 |
looks like mine so if you are wrong so am I
10-23-2014, 08:45 PM | #5 |
Buying aftermarket replacement parts does not mean they fit you may have to provide some creative fitment procedures .in other words just because some parts suppiler says the fit does not mean they actually do ! buy NOS or deal with after market
10-23-2014, 08:51 PM | #6 |
Litew8's got it right. I've heard this complaint from several, mainly that the seal is rock hard and will not allow the rear of the hood to close. I got lucky and found an NOS seal. I have seen the seal from Presision, seems to be much more pliable and should work fine.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
10-23-2014, 08:53 PM | #7 |
I've read several threads the last few years discussing the lousy fit of the repop seals so, I guess you are not alone. Here's a link to one thread that comes up if you search for "cowl seal".
http://67-72chevytrucks.com/vboard/s...d.php?t=394421 |
10-23-2014, 08:58 PM | #8 |
JC Whitney sells Presision gaskets cheaper than most after market shops
10-23-2014, 09:21 PM | #9 | ||
project: "my happy mess" Last edited by litew8; 10-23-2014 at 09:35 PM. |
10-24-2014, 12:32 AM | #10 |
18 Till I Die
Pretty sure they are still available from GM?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
10-24-2014, 04:25 AM | #11 |
Mines sittin back in the bag it arrived in. Lifted the back of the hood up when trying to close. Fit like garbage.
10-24-2014, 06:13 AM | #12 |
I used Pression and my hood shuts fine !
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
10-24-2014, 09:17 AM | #13 |
I have the same problem. Mine is from brothers. I've thought about just trimming the height a little.
10-24-2014, 12:55 PM | #14 |
I saw a post from another thread that said the p/n is 6270848, but it has been discontinued from GM. The thread was from 2011. I will be needing one of these as well and will probably go with Precision based on what I have read on the board.
Thanks, Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
10-24-2014, 02:59 PM | #15 |
I got mine from Classic Parts also. No Issue. I cant invision it being so stiff that it holds the hood up. (Not saying it isnt . ) Mine was nice and pliable. Just wondering before we parts bash, this seal goes UNDER the Cowl. Couple of things, was any of you guys hoods adjusted to the cowl WITHOUT a seal installed? Could let the cowl ride lower in that case. Cowl can be slightly shimmed if the hood wont adjust down..
Also if the hood was adjusted to far forward towards the cowl lip, may lift it a little with the seal there. Those seals just seam wimpy to be causing all this. Check all adjustments. Or tell me to buzz off you dont know what your talking about! Im ok with that too . Just trying to help.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
10-24-2014, 03:34 PM | #16 |
After I bought mine from LMC read on here that that is the wrong type it is like an L shape you need one with more of a V shape like this one from ebay:
http://www.ebay.com/itm/1967-1968-19...ff6ada&vxp=mtr Tim |
10-24-2014, 06:40 PM | #17 | |
Thanks alot |
10-24-2014, 06:59 PM | #18 |
I have the LMC one and it lifted the back of my hood. I replaced the dry rotted original. Before replacement, the hood sat even with the cowl.
I haven't yet cared enough to try to fix it.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
10-30-2014, 08:55 PM | #19 |
I am thinking about buying this seal which is for our trucks and lists Part# 6270848:
http://www.parts123.com/corvettecent...89a&ukey=AACCI
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" |
10-30-2014, 09:06 PM | #20 |
Seriously? $14.85
The one I posted is 1/2 that price. Classic Parts of America 38-114 (1967-72) Hood to Cowl Seal 1 $7.95 Actually, last I looked - they may have upped the price $1 to $8.95 Also, keep in mind what we are talking about this seal being installed UNDER is the COWL Cover, not the cowl itself. Cowl: the part of a motor vehicle that supports the windshield and houses the dashboard. Cowl cover: The cowl gasket installs underneath this. Cowl exposed without its cover:
project: "my happy mess" Last edited by litew8; 10-30-2014 at 09:27 PM. |
10-31-2014, 09:58 AM | #21 |
I have always seen it called a "hood to cowl seal".
10-31-2014, 10:47 AM | #22 |
Right. Technically, it's a hood to cowl cover seal. It actually sits on top of the cowl itself, folds over the top of the cowl cover.
10-31-2014, 02:30 PM | #23 |
Weak and worn hood springs are the reason for the ride up. The seal is stiff but weak springs/hinges are the culprit. Typically an adjustment to the rear bolt of the springs will drop the hood and cause it to sit flat even with a cheap stiff gasket.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
