Old 10-24-2014, 02:18 AM   #1
savatreatabvr
savatreatabvr's Avatar
RUSTOLEUM Paint Job! Spray or Roll?
I'll start this off by saying, I would not normally consider this but the economy forced me to thinking about this option! On YouTube there are many videos on spraying and/or rolling a vehicle with Rustoleum paint. Some videos make it look easy so I'm assuming as long as the paint is thinned properly and enough is applied, wet sanding will give you a nice smooth finish. I understand the pros and cons but has anyone tried this?
Without the equipment or place to give a vehicle a normal paint job this option looks do-able to me!
savatreatabvr is offline   Reply With Quote
Old 10-24-2014, 02:39 AM   #2
LilD
LilD's Avatar
Re: RUSTOLEUM Paint Job! Spray or Roll?
Plenty of tutorials all over the web. Doesn't get much cheaper. Probably will choose this option if I ever get to that point with my truck
LilD is offline   Reply With Quote
Old 10-24-2014, 02:46 AM   #3
tinydb84
tinydb84's Avatar
You could probably pay Maaco to shoot your truck for a few hundred during one of their specials and get better results
David
Instagram: myfabguy
Old 10-24-2014, 05:47 AM   #4
S10Fan
Old Heap Driver
Just keep in mind.........Internet pictures can make anything look good. Every speck of the rustoleum will have to be removed before painting the truck with regular auto paint in the future.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 10-24-2014, 10:36 AM   #5
walls
I've had good luck with it on some model A fenders.
The stuff takes forever to dry though. Weeks it seems like.
Maybe in Arizona (low humidity) it would be better.
walls is offline   Reply With Quote
Old 10-24-2014, 10:47 AM   #6
73Super8
73Super8's Avatar
Speaking from experience I sprayed an S10 Blazer with rustoleum black and it turned out great. You just need to thin it really well. It loses it's shine over a while but hey it was $40 bucks at Walmart. I'll see if I can find a pic and post it.
73Super8 is offline   Reply With Quote
Old 10-24-2014, 12:37 PM   #7
Malo83
Cruzzzn' Vet
Malo83's Avatar
Oh I don't know!!! had my daughters car painted with Maacos $299 special
Could have done a better job with some spray paint
Malo83 is offline   Reply With Quote
Old 10-24-2014, 12:41 PM   #8
tinydb84
tinydb84's Avatar
It is definitely hit or miss depending on what prep you do and what shop you go to. My brother's truck was peeling within a year but he didn't do any prep and didn't want to pay them to prep it. Neither one of us was surprised when the paint failed
The shop near me puts out some good work though and there are some threads on here with some great maaco paint jobs.
David
Instagram: myfabguy
Old 10-24-2014, 12:52 PM   #9
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Let's face it MAACO provides the best $300.00 paint job of anyone out there.
But the fact is the words MACCO and Quality go together like Oil & water on a dipstick , except their paint doesn't look as good
johnnyclack is offline   Reply With Quote
Old 10-24-2014, 12:53 PM   #10
savatreatabvr
If you're on a budget like myself, I find this a plausible option. I see a h-ll of a lot of wet sanding in my future, lol!
Old 10-24-2014, 01:39 PM   #11
Jaysonb
Jaysonb's Avatar
Check our summit racings line of auto paint. Its dirt cheap, and sprays great. I have used it on 2 trucks, and a 78 corvette. I have been more than happy with the results.
Jaysonb is offline   Reply With Quote
Old 10-24-2014, 02:50 PM   #12
tylervalo
I've done it both ways, rolling:
And Spraying:
Spraying was much easier (although I didn't actually spray) to do a complete color change due to door jams and interior spaces. He only did 2 or 3 coats opposed to the 10 I did rolling it which made it much tougher, I plan on rolling about 6 more coats on next spring. Be sure to mix it properly with thinner and add some enamel hardener into it. If you prep, paint and sand correctly it'll look like any other vehicle on the road.
tylervalo is offline   Reply With Quote
Old 10-24-2014, 03:01 PM   #13
tinydb84
tinydb84's Avatar
If you are going through that much work why not use automotive paint? I'm not be sarcastic, I actually want to know. Is there any benefit that I don't know about?
They have plenty of budget automotive paints: Omni, Kirker, SPI, Summit, etc.
David
Instagram: myfabguy
Old 10-24-2014, 03:06 PM   #14
tylervalo
For me, I wanted a nice looking paint job but I still want to be able to have fun off-road with the truck. If I spent several thousand dollars I wouldn't feel as comfortable doing that. With the Rustoleum job if I scratch it I can easily sand it down and fix it with a roller in about an hour.
Old 10-24-2014, 05:50 PM   #15
savatreatabvr
And Spraying:
Sweeet truck! What kind of primer did you use and how was it applied?
Old 10-24-2014, 06:02 PM   #16
tucsonjwt
In my case, I don"t have the skills to get a smooth finish. When I try to rattle can even a small metal piece, I find that the over spray from subsequent neighboring passes flies over the previously painted areas and ruins the glossy finish. Also, I find it hard to get just the right amount of paint to avoid runs.
I am looking at getting a gallon of urethane one step paint and having a local small cheap shop paint the truck for about $250. The paint looks about $150 per gallon.
tucsonjwt is offline   Reply With Quote
Old 10-24-2014, 06:08 PM   #17
ol_skool_chevy
ol_skool_chevy's Avatar
I have done mine and about 10 others all in Rustoleum....And they all worked out ok..But as said before. You will have to remove it ALL before you use regular paint as rustoleum uses oils in the paint to keep from rusting..
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 10-24-2014, 07:04 PM   #18
Just call me Sean
Just call me Sean's Avatar
I prefer Krylon.
I sprayed it. Came out a bit blotchy because of the humidity so I need to redo a bit.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 10-24-2014, 09:07 PM   #19
73GMC10
73GMC10's Avatar
I followed this guys guide with the Canada version of rustoleum(tremclad) for a vehicle I was selling and it turned out great,little bit of sanding and some trial and errors with wetsanding too much in areas but yeah I wish I had picture it was gloss black.
http://www.meguiarsonline.com/forums...paint-job-quot
I will be doing the gloss black roll on method on the 73 gmc 4x4 i just got it wont be as meticulous until next year, I already painted a few pieces,just anything to get rid of that rustic orange for now,lol
*edit I did find a pic the girl took on the phone after I rolled on the 73 lately, as well as i did this old white spoke wheel with rustoleum engine enamel, it works great for rims
73GMC10 is offline   Reply With Quote
Old 10-24-2014, 09:19 PM   #20
SkinnyG
SkinnyG's Avatar
I rolled Tremclad (Canadian equivalent of Rustoleum).
I suckered Home Depot into trying to colour-match the original blue as best they could. Came out a nicer hue.
I did not even thin the paint, just straight from the can. Three coats, sometimes scuffing in-between with a green scrubbie. Because of this, the paint is on THICK, and there is enough orange peel to give you canker sores. But, it's super easy to touch up. The paint texture hides my bodywork defects.
Why did I do this?
1) I am not willing to spend the time to make every panel perfect.
2) I am not willing to spray an iso-cyanite without a booth and breathable air.
3) I am not willing to spend the time and money to do this properly, knowing that it WILL rust again, it WILL get rock chips, and it WILL get door dings.
4) It is a truck. It will get used as a truck. I do not want to be afraid to drive it, to use it, or to leave it parked somewhere.
Would I do it again? Probably.
The pictures hide the surface well. It is nowhere near as good as it looks.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 10-24-2014, 10:23 PM   #21
savatreatabvr
Why did I do this?
Thank you for your time and pics! What would you say the whole paint job cost you from start to finish? I'm a house painter so I won't be spending money on prep materials but since I intend to paint the inside of the bed I'm assuming the paint will be around $100?
Old 10-24-2014, 10:52 PM   #22
SkinnyG
SkinnyG's Avatar
$60 in paint. $15 in primer (needed for the white to cover well). CDN prices.
Couple rolls of painters tape. One roller per coat (three coats each colour).
Old 10-25-2014, 11:45 AM   #23
savatreatabvr
I decided to stay with the original blue & white because my dash and door jams are the same color Just curious, what made you stay with the original color?
Old 10-25-2014, 02:47 PM   #24
SkinnyG
SkinnyG's Avatar
Staying factory colours meant I didn't have to strip and paint the interior and jambs, which would annoy me if I didn't.
Old 10-26-2014, 01:05 PM   #25
lilpoindexter
lilpoindexter's Avatar
Roll...or brush
lilpoindexter is offline   Reply With Quote
