Old 08-15-2003, 11:33 AM   #1
landon4421
Life is Good !
landon4421's Avatar
Question electric water pumps
I was looking to put an electric water pump on my 350. I like the CSI water pump, it says it pumps 30-37 GPM. Has anyone here used one before? I was looking for some input, pros and cons and such. If anyone can help that would be great. Thanks Landon
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 08-15-2003, 11:43 AM   #2
miket
miket's Avatar
Landon,
It's been questioned before whether they actually pump enough water...I have one on my 66 (pic attached) and have cooling problems. However it's a race motor that wasn't designed for steet duty....but after asking several people and doing some research the continual response was that these pumps are for 1/4 mile cars.
Thats not to say it won't work...assuming you have a stock motor and a good/large radiator.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 08-15-2003, 11:58 AM   #3
smokekiki
Mike
smokekiki's Avatar
Why do you want one?On the street you will not lose that much HP.If it is a street truck,I would go with a good belt drive pump.If you want to free up some power,put in a good set of electric fans with a shroud.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-15-2003, 12:03 PM   #4
landon4421
Life is Good !
landon4421's Avatar
I was planing on going with the electric fans also. I was going for looks and to save as much hp as possable.
Old 08-15-2003, 12:06 PM   #5
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
i've been told you 'can' run them on a street motor as long as things are pretty mild as they dont have nearly the flow of the mechanical models. and for the price tag get yourself a good aluminum one from weiland or someone for half the cost... that way you'll not have overheating issues.
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 08-15-2003, 12:20 PM   #6
djracer
djracer's Avatar
Miket
That thing looks fast! How fast is it and do you have it on dragtruk.com if not you should have. That site was started by a bunch of dodge guys. I can't wait to get my drag truck done but my chassis man is way slow!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 08-15-2003, 12:47 PM   #7
72gmcshorty
72gmcshorty's Avatar
MikeT, what kind of fan setup is that?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 08-15-2003, 02:56 PM   #8
miket
miket's Avatar
DJRACER:
it's not my truck....rather my Chevelle...don't know how fast...was told 9.40-9.80 by the builder on initial 6 passes....but things like this are always exagerated.
72gmcshorty:
The fans on my Chevelle are from Flexalite (http://www.flex-a-lite.com/) twin 14"'s that run all the time...no thermostat.
I have twin 14"'s in my truck that are very nice...I can post pics if you want.
Old 08-15-2003, 07:51 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The aftermarket industry says that electric water pumps can not really be used on the street. They say when detroit (Or japan probably) switches over to a 32 volt system, (!!!) then electric water pumps will be able to do the job properly.
