swapping rear end in my 65
I found a 68 12 bolt. Im wondering if anyone has had any issues with the tires hitting body line when trying to lay frame. I have a 65 burb.. I'm guessing it would be the same as a fleet side? My wheels are about 10" wide. I'm running spokes with adapters. Im guess that might had a half inch at most??. Id hate to spend over a grand just to narrow the rear end a couple inches. My tires are about 28" tall.Thanks in advance.. here's a pic for attention.
Re: swapping rear end in my 65
The 68 rear ends are wider then your 65 rear end. About 1 1/2 inch i believe. plus the lower you go from stock the rear end will be pushed closer to your body unless you have a adjustable track bar...Others can ring in and add more I'm sure.
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
I thought it was 73 and newer?
Very possibly, but my thought was 67 and newer were wider...I could be wrong but Im sure others will know more then me
![]() Join Date: Jan 2011
I think it is 72 and newer. When they went to the 5 lug and the disc brakes the track got wider. Just as with the fleet sides and trying to get real low the rear wheel can get into the roll in the body. Also a 10" wide 28" tall tire is a lot to try and lay frame with with no body mods. You can get a rough measurement of your max tire height by measuring from the frame to the ground and the top of the wheel well to the ground and subtract the frame measurement. That will tell you how far it is from the body parts to the ground. Tire has to fit in that space.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
I think the 63 to early 70 12 bolt is 62" WMS to WMS and from late 70 to 87 the width increased to 63.5" WMS to WMS.
Never Ending Projects
Yes, what he said!
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#8 | |
![]() Quote:
Hopefully a burb-owner will chime in...they know more about these burbs than GM ever knew! **I agree w/DLW on width--didn't add the extra 1.5" 'til mid/late-year 1970. Sam Last edited by luvbowties; 10-24-2014 at 03:21 PM. |
what He said........
I know I'm going to get flack over this but what about using a Ford 9" rear end? A lot stronger and parts readily available. Here's some measurements. Ford F100 1957-1972 = 61.25" WMS to WMS, Ford full size cars 1964-1971 = 61" WMS to WMS, 1967 Cougar = 60" WMS to WMS, 1958-1960 Edsel's = 60" WMS to WMS. Yes, I plan on using a Ford 9" in my 64 C10 which is why I have all the research done.
Well... I guess all this is gonna force me.into getting the rear end narrowed..I think quote was for my original 6 lug rear end is roughly 1400.. shorten it 4" 5 lug axles. New bearings and new gears.
