08-15-2003, 11:43 AM | #1 |
Steel Blazer Tank Conversion Install
Anyone done the steel Blzer tank conversion in a P/U? Looking for pictures or advise on things to look out for when doing it. Received my new tank kit yesterday.
08-15-2003, 01:03 PM | #2 |
Steel Blazer Tank
Just put in the steel tank about a month ago. The main problem will be the bed support that is in the way of the tank's filler neck. If you try to mount the tank tabs in the factory frame holes it will put the filler neck right in the middle of the bed support. I bent the tabs down and slid the tank about 2" back so the filler neck is to the rear of the bed support. The only other thing is fabricating a filler location. Determine if you want to cut through the fleetside or not, if not, you can run it up through the floor of the truck behind the drivers wheel well inside the bed.
Any questions, just e-mail me. 72 longbed philwec@fast.net |
08-15-2003, 04:52 PM | #3 |
Here is a pic of a "Kick Butt" way to do the filler neck. I will be redoing mine this way!
Alex 1971 Lil' Red 350 SBC 700R4 |
08-21-2003, 01:17 AM | #4 |
chevydude,
any instructions, parts, or special considerations on how to install that setup? it looks sweet |
08-21-2003, 09:50 AM | #5 |
Post Whore
Contact Tennman as that is his truck - very aweseme, here's another pic.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
08-21-2003, 10:27 PM | #6 |
I seen where they were using a s-10 door, What about the filler tube , Whats it off of?? Starting this project soon?
08-25-2003, 10:51 PM | #7 |
Best Idea I have seen
That is a very good idea, very inventive!!!!
John Sacramento Area 1969 C10 Fleetside |
09-14-2003, 01:07 AM | #8 |
Anybody done this to a stepside?
Douglas King Independence, MO |
09-14-2003, 07:55 AM | #9 |
67-72 Addict!
That does look cool. I also like the flip down tail light lense version.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
09-14-2003, 02:02 PM | #10 |
I am in the process of installing a poly tank with the filler location just like this. Go to http://www.classicheartbeat.com/ under the How to section Wes posted the instructions along with more pictures.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake 1968 C10 flatbed 307 w/ 4 spd manual (dads old ride) 1936 1/2 tn pickup, 400sb 350 turbo (partially restored) 1949 1/2 tn, needs complete restore (future project) 1969 Chevy impala 4 dr no post (wifes future car) 2010 GMC Serria 4x4 crew, leveling kit |
09-14-2003, 07:38 PM | #11 |
Thanks Red, Its what I been look for.
09-14-2003, 10:49 PM | #12 |
Here is mine. About 60 hours involved in it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
09-14-2003, 10:51 PM | #13 |
Filler Neck
01-25-2004, 03:14 PM | #14 |
Has anyone tried using the original filler neck an plumbing it to the frame mounted tank?
67 GMC SWB Project:60 4BM 350 4SPD 67 Chevy C10 Custom LWB V8 Project 69 LWB IL6 3 on tree project 71 SWB Frame off project 72 LWB C10 Factory Tilt Project. |
01-25-2004, 03:31 PM | #15 |
Why not just weld the original filler nech to the cab ?
01-25-2004, 03:37 PM | #16 |
What are you looking at?
there is a nice write up with pics on the FAQ's section of this board
1971 GMC LWB 2005 Honda Element 2007 Honda Fit |
