One injector working
How do I repair an injector that's not spraying, is it a electrical problem or just need to replace it?
#2 | |
Re: One injector working
Swap injector plugs. That's how I checked mine. The wires are long enough to plug into either. It was clogged so I got another one.
I will try that
Just here to tinker
![]() Join Date: Jun 2008
Get an ohm meter and ohm out the pins on that injector and compare it to the other injectors. Injectors can usually be overhauled at an injection shop for around $40-60 each, depending on the shop.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
#5 | |
Other injector, there's only two. So that wouldn't help as much as it would if there were eight to compare.
I think, from memory, that a low impedance TBI injector will measure around 4 ohms. Also, with the ignition key on, one of the two wires that goes to each injector will be 12V hot. The ecu grounds the other wire to open the injector. And, if you point a timing light at the injector with the engine running and the air cleaner off, you can visually see the spray pattern.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
I swap plugs on the injectors and it's still not working
#8 | |
It's clogged. I got a whole throttle body at the junkyard for $25 and used an injector from it, but new ones I priced at about $60 each at AutoZone.
Going to change it... Thanks for the help
Tags |
87 r10 |
