Old 10-25-2014, 04:21 PM   #1
yoshi
yoshi's Avatar
Shifter
Running an sbc350 with Th350 auto, I'm gonna keep the bench seat. Will I have to use the Lokar shifter that's got a bent rod for a bench seat? Or can I use the straight one? Thanks
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 10-25-2014, 05:42 PM   #2
thebebop
thebebop's Avatar
Re: Shifter
We are installing a lokar for the 700r4 now. It is the 23" model and has the bends in it. We are having to move it all the way forward on the mounting bracket to clear the bench seat so had to order a bell adapter kit to make it work. Even with that on it there is zero room when it's shifted into the lowest position.
I don't think there's a lot of difference in mine and yours but you might want to call Lokar and ask before making the purchase.
1955 2nd Series Truck
thebebop is offline   Reply With Quote
Old 10-25-2014, 05:44 PM   #3
yoshi
yoshi's Avatar
Re: Shifter
What have others on here fitted?
yoshi's 49 project
Old 10-25-2014, 08:45 PM   #4
47 Fasttoys
47 Fasttoys's Avatar
Re: Shifter
I have used both the strait and the bent shaft from Lokar. Both will work but both will press on the seat at the lowest gear.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
