Old 10-25-2014, 05:15 PM   #1
crossfire84
crossfire84's Avatar
AD wiper mount
I need to mount the wiper motor but i do not see where it should go, there are no brackets of any kind under the dash. P.O. stripped every thing out. Any help?
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 10-25-2014, 08:27 PM   #2
Cheyenne75
Re: AD wiper mount
The wiper motor mounts up just to the right up under dash, next to dash brace. Roughly behind the temp, gas, oil, volt gauge is.
Cheyenne75 is offline   Reply With Quote
Old 10-25-2014, 09:41 PM   #3
crossfire84
Re: AD wiper mount
thanks.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 10-25-2014, 09:54 PM   #4
nvrdone
Re: AD wiper mount
Shouldn't the mount be up to the right of the dash brace - behind the speedo ?
nvrdone is offline   Reply With Quote
Old 10-25-2014, 10:13 PM   #5
Iceburgh
Iceburgh's Avatar
Re: AD wiper mount
Not the best pic but you can see the motor hanging in there. I will look for a better shot
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 10-25-2014, 11:12 PM   #6
mr48chev
mr48chev's Avatar
Re: AD wiper mount
Here is the stock bracket minus the wiper motor in a 53 cab.
The dash was cut out several years ago because we were going to put a different dash in the truck.
My ongoing truck projects:
Old 10-26-2014, 10:05 AM   #7
crossfire84
Re: AD wiper mount
Thanks, That bracket is gone in my truck, plus i have a hanging pedal assembly so im not sure that wiper motor will fit.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 10-26-2014, 07:13 PM   #8
mr48chev
mr48chev's Avatar
Re: AD wiper mount
An electric one that bolts to it might not work with hanging pedals but I had hanging pedals in mine at one time when it was subframed with the stock wiper motor.
I've got a cable driven wiper setup from Specialty Power Windows that I bought years ago and never used that will go in the 48 this time simply because I have it.
Old 10-27-2014, 04:38 PM   #9
crossfire84
Re: AD wiper mount
I may try this from speedway motors.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 10-28-2014, 06:28 AM   #10
47 Fasttoys
47 Fasttoys's Avatar
Re: AD wiper mount
I used that same unit on my '31 Oakland. It had overhead wipers and it worked great and was an easy install. The nice thing about it is you can place the motor just about anywhere.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 10-28-2014, 05:02 PM   #11
crossfire84
Re: AD wiper mount
good to know, thanks .
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 10-28-2014, 05:14 PM   #12
mr48chev
mr48chev's Avatar
Re: AD wiper mount
That's pretty much the same unit I have for mine.
Old 10-28-2014, 09:08 PM   #13
Iceburgh
Iceburgh's Avatar
Re: AD wiper mount
For the guys that have the speedway unit...is the throw on this unit better than stock....stock just does not clean enough of the window
1953 suburban build
Old 10-29-2014, 06:24 AM   #14
47 Fasttoys
Re: AD wiper mount
The throw is adjustable by using a different position on the cam wheel. IIRC you could get up to 110 degrees of movement. For my Oakland at rest they where at the top of the windshield and while running the ends would just about touch the edges of the frame. Total sweep was over 90 degrees.
Rob
My '47 C.O.E build
