Old 10-25-2014, 06:04 PM   #1
72freak
Rottenwood Garage Member
72freak's Avatar
86 C10 climate control not changing possition
86 Silverado. New to me. The fan is working and the temp control is working but it will only blow out of the face vents. Wont change to floor or defrost. Is that a vacuum line? Any hints on where to start to save me from tearing into the entire thing?
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 10-25-2014, 06:29 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: 86 C10 climate control not changing possition
Yes, vacuum. Start by checking the feed under the hood.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 10-25-2014, 10:32 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Blender door clip can be broken or the vacuum line to the motor isn't connected be the firewall
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-26-2014, 10:42 AM   #4
Jake Wade
Jake Wade's Avatar
Yes, that blend door plastic piece is well known to break.
Jake Wade is offline   Reply With Quote
Old 10-28-2014, 11:58 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
1.if the rods are ok
2.check white piece that breaks is behind the glove box
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-01-2014, 05:07 AM   #6
72freak
72freak's Avatar
Thanks for the info guys!
It was in fact the feed under the hood.. The small hard plastic vacuum line that comes out of the firewall beside the heater box was broken. Easy fix. For those having the same issue, I would start in the engine bay first when trouble shooting this especially if you have been doing engine work prior to the problem. That line is hard and brittle. Make sure you hook it up to constant vacuum. If that doesn't work then head inside under the dash and stand on your head.
