Gearvendors Overdrive Anybody using one?
I know there is talk about these on here but really havent heard anybody using one. I know they are pricey and a 700 tranny would probably be plenty for me. I am just wondering how fast and how well they shift in and out. I understand you can shift between each gear to get 6 automatic speeds. Sounds good but what does the users think?
Tell us about them if you have one (or know someone that does) Thanks Dave ![]() ![]() ![]() ![]() ![]() ![]()
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
if i had the money ($3700) i would definatly go fot a TH400 with a gearnendors setup
Fabricate till you "puke"
I looked @ the vendors, but for the money opted for a Richmond 6 spd......
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
a gear vendors unit would be pretty sweet, but they are prohibitively expensive. i would rather do a Clark or NV4500, or even an NV5600 swap. Those would be expensive too, I guess getting OD for these old vehicles just aint cheap. altho the gear vendors would net me more overall gears (8 vs. 5 or 6, and 4 now).
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
![]() Join Date: Jul 2003
A freind of mine was running one on his 455 Buick Regal before he sold the cqar.. He liked it alot.
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
