Old 10-25-2014, 11:55 PM   #1
mwj57
LS swap/IRS pinion angle?
So i'm building a 57 chevy truck with Lincoln Mark viii IRS and planning on running an LS motor up front. I'm wondering what is the preferred angle to set an LS motor at. I understand that with IRS the pinion is fixed and will not rotate up like a traditional rearend so it just hast to be parallel to the motor. I've seen posts suggesting 4 degrees on the motor to prevent oiling issues. Anyone have thoughts on the subject.
mwj57 is offline   Reply With Quote
Old 10-26-2014, 12:10 AM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: LS swap/IRS pinion angle?
What I understand is that the typical engine/transmission angle relative to a 0* on the frame rail is 6 * on a GM vehicle. With that said, if your pinion angle is 6* you will not have any working angle on your u joints. All automotive u joints require a working angle of at least a 1/2* to prevent bearing caps from seizing up. They all need to rotate. Also you need to be concerned with phasing as well.
I would contact board member NEWFISHER as well as he is doing some drive tran modifications on his 46 soon.
Here is also a link that will help you with your question.
http://jniolon.clubfte.com/driveline...nephasing.html
Hope this helps
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
