Old 10-26-2014, 08:25 PM   #1
hardwaycooke
hardwaycooke's Avatar
Front Indicator LED problem..
All my lights work great, I just put new bulbs in the cluster, new switch, and new grounds on the panel and signal housings- was having some issues but no more.
Now, all I want to do is put a LED 1157 bulb in the front housing for my blinker/park lights. As soon as I did, when I turn my lights on, the cluster indicators come on steady. The blinkers work but indicators are on steady when not blinking. I bought new non thermal flashers and still the same thing.
Any advice? One flasher said electronic-from Oreillys, and the other said heavy duty and electronic from Autozone. Neither had 2. thx!!
hardwaycooke is offline   Reply With Quote
Old 10-26-2014, 08:39 PM   #2
POPO1984
POPO1984's Avatar
Re: Front Indicator LED problem..
I don't think there is a solution for the parking lights being led. Something about them grounding through the bulb.
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 10-26-2014, 09:01 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Front Indicator LED problem..
Dennis,
To run the LED's you need the grounded blinkers.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-26-2014, 09:32 PM   #4
hardwaycooke
Originally Posted by Andy4639 View Post
Dennis,
Thanks Andy..once again you saved my brain from exploding.. ok..where do I get them? Do I need 2? Where do I ground them> Thanks again!!!!!
Old 10-26-2014, 11:12 PM   #5
BruthaMan
US Army Veteran
BruthaMan's Avatar
Small world. About three weeks ago, I added LEDs for the blinkers and had the very same problem. It was not easy getting the LED 1157's to seat, either.
Thought maybe it was just a bad set of LEDs, because they lit up in the cab when I turned the headlights on.
BruthaMan is offline   Reply With Quote
Old 10-27-2014, 01:32 AM   #6
POPO1984
POPO1984's Avatar
Let me know if it works. I was under the impression that the parking lights would not function correctly. Every other bulb I have is led except those.
South Houston
Old 10-27-2014, 09:53 AM   #7
hardwaycooke
I ordered a pair of the flashers from summit. I'll try it and send 'em back if its a no go... I'll keep yall posted...
Old 10-27-2014, 01:28 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Front Indicator LED problem..
Mine work great. Dennis just ground it to anything close to the fuse panel. I used the park brake mount. I have LED's in everything in my 71 truck except for the headlights and fog lights.
Old 10-27-2014, 01:51 PM   #9
hardwaycooke
Dang it! Nice truck A. I'll do it tomorrow when the flashers come in. I love the fog lights in the bumper. I was thinking about getting a 69 grill and using the park lights as fog lights but like yours better.
What about LEDs in the cab and cargo lights? Do the 2357s work fine in the rear lights to make them brighter??
thanks!!
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
Old 10-27-2014, 02:55 PM   #10
Andy4639
Old member
Andy4639's Avatar
I have a set of van lights inside so they are good and bright. I have the LED brake lights though.
Old 10-27-2014, 03:48 PM   #11
POPO1984
POPO1984's Avatar
Sweet ill order some LED 's for the front now
South Houston
Old 10-27-2014, 06:53 PM   #12
Andy4639
Old member
Andy4639's Avatar
Here is a better shot of the LED parking/turn signals.
Read this also. The flashers got it straightened out for me.
http://67-72chevytrucks.com/vboard/s....php?p=5393945
Old 10-27-2014, 07:07 PM   #13
hardwaycooke
Do I need to replace both flashers??
71 LWB
B&M Pro Shifter
Truck Name- Spike
Old 10-27-2014, 07:13 PM   #14
hardwaycooke
Can you use cargo/cab light LEDs without issues??
71 LWB
B&M Pro Shifter
Truck Name- Spike
Old 10-27-2014, 07:16 PM   #15
Andy4639
Old member
Andy4639's Avatar
I would think so. They are on a seperate circuit. I used both flashers.
