Old 10-27-2014, 08:11 AM   #1
aris_unlimited
old style locking hubs
I've talked to guys before that mentioned the locking hubs they had "back in the day". The way they described it was that they didn't have the switch you turn like most do. They (I've heard this from multiple people) said that you wrapped your hands around the whole hub and turned it instead.
Any thoughts on whether people still make something like this?
1974 Plymouth Satellite (driver, project)
1972 GMC 2500 (future project, does drive though)
aris_unlimited is offline   Reply With Quote
Old 10-27-2014, 10:11 AM   #2
andrewmp6
Re: old style locking hubs
Look up mile marker selectro hubs probably those.
andrewmp6 is offline   Reply With Quote
Old 10-27-2014, 08:34 PM   #3
patdaly
Still available for some, pricey though.
http://shop.milemarker.com/p/classic...-ford-rockwell
patdaly is offline   Reply With Quote
Old 10-27-2014, 10:17 PM   #4
landy
I've got a pair of Selectros on my '72 Blazer with Dana 44. It's too bad they're only made for a few front axles anymore.
landy is offline   Reply With Quote
Old 10-27-2014, 11:08 PM   #5
Ziegelsteinfaust
Are these better then then new style? Or do they have a tendency to unlock when hit.
Ziegelsteinfaust is offline   Reply With Quote
Old 10-28-2014, 03:32 AM   #6
aris_unlimited
I guess you are one of the lucky ones, I was just looking on their website and they only have the ones with a switch rather than turning the whole thing for Dana 44's now. Which really sucks, because I wanted it for a dana 44 lol.
Old 10-28-2014, 06:48 AM   #7
dfrank
dfrank's Avatar
I believe they only work with external hubs.
dfrank is offline   Reply With Quote
Old 10-28-2014, 02:06 PM   #8
landy
I've never hit anything with them, but I suspect they'd be more likely to break than unlock if getting hit by rocks. Probably any brand lockout is likely to break if hit hard enough.
Old 10-29-2014, 03:38 AM   #9
aris_unlimited
Maybe I'm missing something, but my hubs do stick out past the wheels...wouldn't that be considered external hub?
Old 10-29-2014, 08:03 AM   #10
dfrank
dfrank's Avatar
No, both internal and external hubs stick out past the the wheel. Read this to get a better understanding of the differences. http://www.pirate4x4.com/forum/newbi...rnal-hubs.html
Old 10-29-2014, 11:52 AM   #11
aris_unlimited
So is there any type of hub lock that will work with an internal hub that is easier to turn? I have big hands and fingers so reaching in to grab these switches can be a bit of an inconvenience lol.
Old 10-29-2014, 02:17 PM   #12
landy
Selectros may be your best choice since they're easy to turn. You may be able to find a used set if you are vigilant.
Old 10-30-2014, 05:40 AM   #13
aris_unlimited
I have found a couple on ebay that say they are for Dana 44s but they also say 19 spline, and I am pretty sure mine would be a 30 spline. I have no idea if that would actually make a difference.
Old 10-30-2014, 12:31 PM   #14
BLT gmc
My 69 GMC K10 has 30 spline axles on the differential side and 19 splines on the hub side. Good luck, Bruce
BLT gmc is offline   Reply With Quote
Old 01-01-2015, 11:39 PM   #15
MyDad'sTruck
I've used a set of open pliers to turn my old warn hubs. Good leverage.
MyDad'sTruck is offline   Reply With Quote
Old 01-08-2015, 06:57 PM   #16
OrrieG
OrrieG's Avatar
My dad always ran these on his jeeps in the 50's and 60's, we used them hard and never had a hub failure. He was buying military surplus so it may have been what the govt. spec'd. I was not ambitious enough to search and see if they are still made or were even available for GM hubs. You flipped the levers, turned them 180 degrees and flipped them back into the slot to engage and disengage.
OrrieG is offline   Reply With Quote
Old 01-08-2015, 07:12 PM   #17
Those are Dualmatics. My dad ran those on his '62 Land Rover. Those are tough as it gets. I have a set for my '72 K2500
Old 01-08-2015, 07:14 PM   #18
michael bustamante
michael bustamante's Avatar
i have an old wrap your hand around set that my uncle used on his half ton chevy back in the 70`s real neat retro looking
1967custom
michael bustamante is offline   Reply With Quote
Old 01-09-2015, 12:08 AM   #19
landy
I also had a pair of those dualmatics on a '60 Series II Land Rover. They did seem pretty stout.
Old 01-09-2015, 12:34 AM   #20
undertaker72
undertaker72's Avatar
I had dualmatics on my 59 fleetside napco , , you pull the arm out rotate 180 fold it back , I never ever had a problem , bulletproof , I wish things were as good now as they were back then
undertaker72 is offline   Reply With Quote
Old 01-09-2015, 11:35 AM   #21
I agree. I guess it's nostalgia having a thing for these old hubs, but it's the appreciation of the quality as well. In fact, I always considered factory hubs plastic junk and switched them out right away.
Old 01-10-2015, 06:08 AM   #22
aris_unlimited
I'm only 31 and I still love the old stuff. Considering my first car was made in 88 and pretty much newer stuff from there on out. I had a couple classics and now I prefer them. Easier to work on, more reliable etc. Especially considering the last 4wd I had was a 2007 tahoe, only had 100k miles on it and something went wrong with the 4wd in the front axle. I wasn't going to pay $400-$2000 to fix it depending on what it was so now I have a 72 GMC lol.
Old 01-20-2015, 12:47 AM   #23
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
The OEM spicers like in my avatar are good units and easy to turn with two fingers as long as you do the maintenance on them every few years and don't use heavy grease. Gear lube seems like the way to go on them. Can't beat the look of OEM either.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 01-20-2015, 10:17 AM   #24
Not to argue here. I agree the Spicers are perfectly good hubs. But the hubs we're talking about here are better, if for no other reason, no plastic. Figure Spicer first made all metal hubs, too. Then by '69*, when most trucks got lock outs, they went to plastic (I figure) as a way to gain more profit. It certainly wasn't to make them stronger. One of the biggest mistakes people make is using grease outside of the wheel bearings. The other is doing no service at all. Servicing required, clean and lube...with oil.
* Plastic in grille,too. And in '72, first plastic door panels. In '73, mucho mas plastico
I do different things on different trucks. I'd use Spicers on an original truck, and have had them on about every truck I've had. But, it's way cool to use period correct upgrades on the right truck, just like Hickey stuff, Eagle Ventures hoods, aluminum slots, Ramsey winch/bumper, etc. I started out modifying these trucks when they were newer. Who wants a boring stock old man truck? And I why not increase performance to add to the pleasure? I've bought most of my cool aftermarket hubs from guys who had to have the Spicers. i like them all. I have a N.O.S. set of Spicers and even some red '70 nobs to color coordinate my GMC.
Those knob-type Selectros were available from many sources with their own name on them. Here are some examples:
Old 01-20-2015, 02:51 PM   #25
61K10
61K10's Avatar
old spicer hubs on my k61 (wheels have been re-painted--was to cold)
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
