10-27-2014, 10:42 AM | #1 |
Should I be Concerned About This?
These gaps in between the wheel and the hubs? I bought my wheels off a guy who had them on a K5 so they should be the same right? I'm wondering if I need some sort of rings to fill in that space between the wheel center and the hubs.
My Wheels: 1984 Chevrolet K/10 Scottsdale 350cid *SOLD* 1989 Cadillac Fleetwood Brougham d'Elegance 307cid 2015 Chevrolet Silverado 1500 LT Texas Edition 5.3L 4x4 |
10-27-2014, 10:53 AM | #2 |
Re: Should I be Concerned About This?
No, the lug nuts center the wheel. From what I have been told by a rear end shop, the hub center on the axle centers the brake drum or rotor...not the wheel.
John 82 Chevy Silverado 350ci/TH350 |
10-27-2014, 04:03 PM | #3 |
Ok, so the lugs don't need help from the hub.
10-27-2014, 05:47 PM | #4 |
That is the case with 99% of aftermarket wheels.
OE Wheels would be supported by the hub, and the lugs/nuts would hold the wheel to the hub. Most aftermarket wheels have the wheels supported by the lugs/nuts. hub centric vs. lug centric. |
10-28-2014, 04:03 PM | #5 |
It'd be alot cooler if you did
looks like you're running tapered lug nuts and a shouldered wheel. Are the holes on the wheel tapered? If not you'll need the correct lug nuts since the wheels are not hub-centric.
10-29-2014, 11:51 AM | #6 |
I'm not sure. I'll buy the correct ones if they're not already, what do I look for?
10-29-2014, 12:16 PM | #7 |
Another Day, Another Dollar
There will be a bowl shaped taper under the head of the nut. It will align with the bowl shape in the stud pilot
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
10-29-2014, 04:24 PM | #8 |
Here's some info on lug nut styles.
You likely have conical seat ones on there but need the mag style. http://www.performanceplustire.com/t...About-Lug-Nuts |
10-31-2014, 01:49 PM | #9 | |
10-31-2014, 02:30 PM | #10 |
Take one of them off & confirm what you have first.
