Old 10-27-2014, 03:18 PM   #1
sambudo
sambudo's Avatar
checking compression Inline 6
Can you check the compression with the engine out of the truck?
Is it possible? How would you go about doing this?
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 10-27-2014, 04:20 PM   #2
trac209
Re: checking compression Inline 6
Same as in the truck. Plugs out,throttle open or carb off if it's already off. Hook up battery to starter and either put a switch in or jump the solenoid. Use gauge as usual. Make sure engine is stable and nothing is going to get caught on ring gear etc
trac209 is offline   Reply With Quote
Old 10-27-2014, 09:04 PM   #3
Exgie
Just do a leak down on it.
Exgie is offline   Reply With Quote
