Old 10-27-2014, 07:09 PM   #1
gripnrip
Gripnrip
Gear ratio ?
Checking gear ratio and count 41 on the ring and 18 on the pinion. My calculations give a .439 ratio. Any ideas?
gripnrip is offline   Reply With Quote
Old 10-27-2014, 07:31 PM   #2
NC67Chev
NC67Chev's Avatar
Re: Gear ratio ?
wouldn't that be 2.28?
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 10-27-2014, 07:35 PM   #3
SS Tim
SS Tim's Avatar
Re: Gear ratio ?
The gear ratio x.xx:1 is based on the number of driveshaft revolutions required to turn the ring gear one time. Thus the ring gear count (41) is divided by the pinion gear (18) resulting in a 2.28:1 ratio.
SS Tim is offline   Reply With Quote
Old 10-27-2014, 07:44 PM   #4
JimKshortstep4x4
Re: Gear ratio ?
I have not ever heard of a a 41 tooth ring gear with an 18 tooth pinion. If this is a truck is there any chance that you miscounted?
My calculations show the ratio is 2.27 to 1 going by the numbers you posted.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-27-2014, 09:03 PM   #5
Exgie
Re: Gear ratio ?
Originally Posted by jimkshortstep4x4 View Post
i have not ever heard of a a 41 tooth ring gear with an 18 tooth pinion. If this is a truck is there any chance that you miscounted?
Jim
2.27777~7778 = 2.28
Exgie is offline   Reply With Quote
Old 10-27-2014, 09:39 PM   #6
Bigdav160
Bigdav160's Avatar
Re: Gear ratio ?
The lowest I've heard of is a 2.41:1 The rear end in my Camaro came out of a '78 Trans Am and it was originally a 2.56:1 (41:16)
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-27-2014, 10:14 PM   #7
kwmech
Re: Gear ratio ?
What type of rear and year, look for numbers on the ring gear
Old 10-27-2014, 10:36 PM   #8
Fitz
Re: Gear ratio ?
You should count those teeth on pinion and ring gear again.
Fitz is offline   Reply With Quote
Old 10-27-2014, 10:45 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Re: Gear ratio ?
Rear Axle Ratios
Ratio 2.56:1 - Tooth Combination 41,16
Ratio 2.73:1 - Tooth Combination 41,15
Ratio 3.07:1 - Tooth Combination 43,14
Ratio 3.08:1 - Tooth Combination 40,13
Ratio 3.08:1 - Tooth Combination 37,12
Ratio 3.31:1 - Tooth Combination 43,13
Ratio 3.36:1 - Tooth Combination 37,11
Ratio 3.42:1 - Tooth Combination 41,12
Ratio 3.55:1 - Tooth Combination 39,11
Ratio 3.73:1 - Tooth Combination 41,11
Ratio 4.10:1 - Tooth Combination 41,10
Ratio 4.11:1 - Tooth Combination 37,9
LockDoc
Leon
Old 11-03-2014, 04:02 AM   #10
gripnrip
Gripnrip
Re: Gear ratio ?
Well I just nominated myself for the "Barney of the month" award. I did count wrong. Turns out I was counting a shaft gear or something instead of the carrier gear. The rear end is in fact a 4.10, 8 lug, 14 bolt. Now I know. Thanks for all the ideas.
