Old 10-27-2014, 07:46 PM   #1
tbs98z
tbs98z's Avatar
Ps leak help!!!!
My Son's 99 GMC has a PS leak that has drained the pump dry and covered the Driver side of the engine compartment in fluid.The front and top of the pump are dry,so it didnt come from the cap or around the front seal area.The fluid obviously sprayed off the bottom of the hood and covered the top of the battery,the brake booster and the master cylinder.After refilling the pump and running the truck I can find no sign of where the PS fluid came from.Any help would be appreciated.
1979 C10 SB CUSTOM DELUXE
1998 Z28
2005 Trailblazer
2008 Silvy
tbs98z is offline   Reply With Quote
Old 11-13-2014, 09:17 PM   #2
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: Ps leak help!!!!
Did you figure it out yet? Could be a split hose? Have someone turn the wheel while you're looking so the system is under load and will leak when you want it to.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 11-21-2014, 04:39 PM   #3
Mr-Jack
Beer Drink'n Knuckle Dragger
Mr-Jack's Avatar
Yeah...find a pile of mud to park the front tires on and turn from side to side while in neutral and revving. if you cleaned everything up in there after the fluid loss, you should be able to find it fairly easily.
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US
- 67 GMC Long-Wide 350/SM420
My BACON Wrapped Meatloaf Recipe
Mr-Jack is offline   Reply With Quote
Old 12-03-2014, 10:57 PM   #4
Atommik
Atommik's Avatar
I wuld suspect the high pressure PS hose. I've replaced mine twice.
Atommik is offline   Reply With Quote
