Old 10-28-2014, 06:07 PM   #1
mach92bill
Kingpins on 3100
Has anyone replaced their kingpins? I'm just wondering if standard .866 dia. or .010 over is the normal. Also, has anyone had to replace the beam axle due to kingpin wear?
mach92bill is offline   Reply With Quote
Old 10-29-2014, 07:12 AM   #2
PGSigns
PGSigns's Avatar
Re: Kingpins on 3100
Been 30 years since I did a set but I tell ya how we did it. Used a snap on king pin press to get them out. The beam axle was never a problem with wear but some time a big problem getting pis out. A little heat would help. The bushing in the spindles would get pushed out and new ones pushed in. Then we would use a long reamer and ream them to size to a good fit on the new king pin. Then drill the grease hole and take a die grinder and work the grove for the grease to get around the pin. There were bushings available that did not have to be reamed but the old school way I was taught seemed to work the best.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
