What Are These Crossmember Brackets?
So I was planning ahead and thinking about my exhaust when I started reading threads on members cutting 4" circles through their crossmember, which I really like!
But, in all of their pics I notice that they do not have some brackets that my frame has. What are these for? Do I need them? Should I still consider running my exhaust through? Thanks everyone! Here is the routing I would like to run Here is my truck frame with these additional bracket/supports:
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
Re: What Are These Crossmember Brackets?
No doubt. Someone added those it appears. They will need to go to run pipes through your cross member.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Loves all GMC trucks
![]() Join Date: Jul 2010
I've had a few trucks with those braces... I think they are on 3/4 trucks, don't quote me. It's been a while since I had a truck with them but those are factory.
They will have to go for your exhaust to run through there. Someone will post the option/reason some trucks had them.
Mike If your helping someone and expecting something in return... your doing business not kindness! |
Could be Mike not familiar with 3/4 ton. His pics looks like a welded after thought. Must be to prevent frame twisting on heavy loads.
#5 | |||
I was thinking maybe thats why, its a 1970 C20 and what I believe to be a camper special. Would that be the reasoning? Last thing I want to do is remove these, run the exhaust, then have the frame or something tweaked after everything is back together. Also, Cash, did you ever remove these braces on those trucks of yours?
![]() Join Date: Aug 2003
Only ones I've seen those on are big block 3/4 trucks.
Thats weird bc I am almost positive this truck had a 350 sb in it. Now I have more questions!
Check you SPID and the exhaust mounts above the rear end. It might have been a BB truck originally. I'm not sure its a BB only item but Uncle may be onto something!
I know when I was tearing it down, there was only one exhaust pipe and muffler. So where would these mounts be on my frame?
I am getting super intrigued here!
Here is my SPID, it says 350 sb. So still trying to figure out why I have those braces.
![]() Join Date: Feb 2012
I have them on my 70 3/4 ton. I converted it to 1/2 ton and adding a high hp big block. I am leaving them for added frame support
Not saying that's a given but that's only ones I've ever seen them on. And coil spring only for me. Are yours bolted or riveted on? Looking at your build sheet, maybe it's 3/4 heavy spring thing?
#13 |
![]() Join Date: Sep 2011
FWIW, They have been on all 3/4 T trucks I have had.........small or big block.
1967 C10 SWB Owner - Rustbelt Restorations |
#14 |
They are riveted in.
It's starting to look like I should leave these in, which is fine. But it's curious I don't see these on other frames often. (Saying this as a newbie)
#15 |
![]() Join Date: May 2010
My 69 3/4 ton with 350, TH400 and coil springs has them.
#16 |
Way better picture, thanks FirstOwner.
#17 | |
I'm not a professional at reading these but the SPID will be easier to read. IF you changed the frame over to 1/2 ton the added strength the support gives is negated by the suspension downgrade as far as weight carrying goes. If I changed the frame to 1/2 to Id get rid of them and get the exhaust clearance above the scrub line. Just my opinion though.
#18 | |
But I won't be making it a 1/2 ton, keep it 3/4. So looks like I'll be keeping them and figuring out the exhaust routing a little later.
#19 |
Some states will allow a turn down after the cab, some just require exit behind the cab to the side. Those are some of the possible options if ur state allows it.
Just when you think you have these year trucks figured out you get educated again.
#20 |
I think it's a 3/4 ton thing. My '68 C20 350/350 camper special had them.
If you aren't using the C20 as a 3/4 ton truck, I vote pull them off. What's the difference between a long bed C10 and long bed C20 when it comes to those brackets. I mean, at least you still have a thicker frame.
'68 C10 SWB '85 K30 Blazer |
#21 | |
I am taking the frame in for blasting tomorrow, should give me some more time to consider what to do before I paint...this weekend hopefully.
