Old 10-29-2014, 07:01 AM   #1
bodydrop
heater box relocating?
Hello, I have a 65 c10. It slammed on the ground and I have to run big wheel tubs up front. Is it possible to flip the heater box underneath the passengers dash. And if so how.
Thanks , bodydrop
bodydrop is offline   Reply With Quote
Old 10-29-2014, 09:40 AM   #2
timmytimm3
Re: heater box relocating?
I filled all the holes and will be running a hot rod style heater under the dash similar to this:
http://www.summitracing.com/parts/sum-991102-1
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 10-29-2014, 12:15 PM   #3
65 C20
Looks like it will give you heat but no defrost unless I am reading it wrong.
65 C20 is offline   Reply With Quote
Old 10-29-2014, 12:42 PM   #4
61K10
61K10's Avatar
find one of these (org. cheap heater) fits under the dash
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-29-2014, 02:26 PM   #5
Improbcat
Improbcat's Avatar
You can add a Defrost Kit off one of the outlets, or make your own to the existing defroster vents with some defroster ducting and a PVC Y pipe.
http://www.summitracing.com/parts/sum-991104
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures)
SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD
Improbcat is offline   Reply With Quote
