Old 10-29-2014, 09:02 AM   #1
OJ1988
Just a car guy
OJ1988's Avatar
Strange problem with88 c1500
So this just started. When driving my truck, after it warms up, while cruising it will randomly cut, or buck, and even if in 5th gear, the shoft light will flicker, with the stumble.
It does It randomly.
Tried pulling trouble codes, none came up.
This is a fresh 350 tbi. Has about 8000 miles on it, including new dist, wires, all sensors, rebuilt throttlebody etc....
Fuel pump was replaced a few years ago.
Just started this yesterday, it's my daily driver.
Where to start?
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 11-17-2014, 11:51 PM   #2
Cabnchassis
Re: Strange problem with88 c1500
What trans?
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually
1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr
1991 CR500 (95 Burb wouldn't stop catching fire )
Cabnchassis is offline   Reply With Quote
Old 11-18-2014, 02:20 PM   #3
ChevyTech
It sounds like heat could be causing the ignition module in the distributor to break down. Many auto parts stores in my area will test the distributor module for free if you bring it in.
The test results from these stores are not always accurate, and some times the will say the module is good when it is not, but for a free test that may find the problem it is worth a try.
Make sure when you install or reinstall the distributor module that you use heat sink compound under it. The compound helps dissipate heat from the module. Without it, the module will fail.
If the distributor module is ok, you should test the fuel pressure with the engine running.
Old 11-18-2014, 10:27 PM   #4
RatPoweredTruck
Grounds? Also, check for spark arching off the wires or plugs.
RatPoweredTruck is offline   Reply With Quote
