View Poll Results: Build a 63 GMC or 66 Chevy Truck | |||
63 GMC Shortbed | 20 | 55.56% | |
66 Chevy on Shortbed GMC frame | 16 | 44.44% | |
Voters: 36. You may not vote on this poll |
10-29-2014, 10:57 AM | #1 |
What to build 63 GMC or 66 Chevy
Kinda dumb question for you guys with lots more knowledge on these year trucks but here goes.
I am trying to decide which truck to build. I bought a wrecked 66 chevy longbed, practically no rust just bent frame, front fender, etc. and while looking for a frame to put under it came across a 63 GMC shortbed with a little more rust, no bed, but also a good buildable truck. Am I to understand that the 66 would have more legroom? I really dig the look of the wraparound windshield on the 63 and these really cool original side mirrors (small square units). Anyhow, I am a muscle car guy and pretty knowledgeable about those, but these years trucks I am a Newbie for sure. Hope to start learning. |
10-29-2014, 12:37 PM | #2 |
Re: What to build 63 GMC or 66 Chevy
This type of question comes up quite abit.
It all boils down to what you want. |
10-29-2014, 01:47 PM | #3 |
Depends on your skill level to repair the cab rust.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
10-29-2014, 02:33 PM | #4 |
I say fix the 66. But it is what I drive everyday so I am biased.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-29-2014, 02:49 PM | #5 |
The GMC frame should have leaf springs on the rear. So install the 66 cab on the GMC frame. Get the front suspension & rear end from a 72 up. You will have five hole wheels . disk brakes on front and a greater selection of rear gear ratios and wheels. Both trucks you have likely have 410 gears or possibly 390,s. They will be winding the engine pretty tight at highway speeds. Both cabs have the same leg room its just the 63 & earlier have the knee knocker wrap around windshield.
10-29-2014, 03:27 PM | #6 | |
I appreciate any and all information. I kinda thought the wrap around windshield might be more expensive too? Possibly saleable after all the dust settles? Don't want to even think about that yet, just trying to start the build plan. Thanks again. |
10-29-2014, 03:31 PM | #7 |
I will get some pics ASAP, or next time I go up to the cabin. The cab rust (what little is there) doesn't bother me at all.
Kinda leaning towards the 66, just wanted to have you guys that know these trucks (strong and weak points) weight in. The 66 dash is perfect and the 63 has had a larger radio cut into it at some point in it's life. |
10-29-2014, 04:04 PM | #8 |
The GMC will have different (and hard to come by) axles and rear brake drums are hard to come by as well (unless you switch out the rearend as well as stated above)..
10-29-2014, 04:09 PM | #9 | |
Just trying to "get up to speed" on this a little during the planning. I think I will swap out the front and rear stuff. Heck I got two whole trucks sitting complete in case I needed parts for my 81 4X4. I appreciate it. |
10-29-2014, 05:33 PM | #10 |
Yes the GMC rears the axle is held in by a pressed on wheel bearing. The chev axles are held by a C retainer. The wrap around windsheld should be a easy sell the same from 1960 thru 63. If you swap to the later disk brake front you need a proportioning valve and a dual master cyl.
10-29-2014, 05:38 PM | #11 |
Thanks.
All the info is flowing. My wheels are a churning. I am already building it in my mind. Still trying to figure out how to break the news to my wife that I now own 10 vehicles. Last month it was only 8. I know. I should just Man up. Lay down the law. Yeah right. Hoping the time will be right, soon, She has 1 car, but that doesn't count. |
10-29-2014, 05:50 PM | #12 |
I personally would do the 66 cab...but that's ONLY based on the fact that more replacement parts are available for the 66 Chevy over the GMC as for the frame I have no insight on that I have never had one...all I know is it's leaf springs not trailing arms.
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
10-29-2014, 05:54 PM | #13 | |
10-29-2014, 06:25 PM | #14 |
No Limit sells a rear frame kit to make lwb into a swb so you could have 2 trucks, 2 are better then 1.
http://www.nolimitengineering.com/pr...=0&sort=normal
10-29-2014, 06:50 PM | #15 |
But Found Her 25yrs Later!
If you scrap the totaled 66 frame, pull everything worth salvaging - like the trailing arm suspension, and all the e-brake components.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
10-29-2014, 07:45 PM | #16 |
1961 crewcab
I will also mention, that I think there is more parts available for a 66 chevy, than the 63 gmc, so the 66 will be an easier build, however both have a lot of support and interchange in the aftermarket, so it mainly boils down to what cab and dash you like best...
the mirrors will work on either truck-
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
10-30-2014, 12:24 AM | #17 |
60-66 Nut
Before you go switching cabs and frames, be sure you know what is required in your state or county for vehicles that have body's and frames with different VIN's. Personally I would leave the body's on their original frames and just upgrade the suspension, running gear and drivetrain to suit your needs. I agree with, which one to build depends on which cab and dash you like better.
10-30-2014, 05:43 AM | #18 | |
10-30-2014, 07:35 AM | #19 | |
I personally don't think I would have a problem with swapping the cab/frame here in AZ as I have clear title to both trucks. We'll see. Thanks again to all who have chimed in. Wayne |
10-30-2014, 06:25 PM | #20 |
Who Me?
Im partial to the knee-knockers, so I vote for the '63.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
10-30-2014, 08:20 PM | #21 |
Would you be so kind as to elaborate? I think they have "very cool" windshields & aren't the dashes different. I have one (63 GMC) on my trailer at my buddies house and the 66 Chevy is about 200 miles away at my cabin. Hopefully by the end of the weekend I will have the two cabs next to each other so I can see the difference myself. Until then I am just wanting to get input as to why different folks feel differently about the two style cabs. In case you guys can't tell I am "chomping at the bit" to tear into this project. Oh yeah, one other thing. My 66 Chevy truck has the original 283 and 4 speed manual trans still in it. I assume it was running (pretty fast if not good) when it was wrecked. Huh,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Still leaning towards the LS/auto though. |
10-30-2014, 08:47 PM | #22 |
as I'm currently restoring a 63' GMC, you should know where my vote lies
10-30-2014, 10:16 PM | #23 |
Knee Knocker!
10-31-2014, 12:06 AM | #24 | |
60-66 Nut
The issue could arise if you were to sell the truck to someone in another state and they need to have a VIN inspection before the new owner can transfer the title.
10-31-2014, 02:55 AM | #25 |
I want to know where all this misinformation keeps coming from about GMC parts??? The trucks sheetmetal replacement parts are all the same as a Chevy. Grills and trim can be painted or rechromed and in some cases bought new. Want the aftermarket dash? Just hunt for it they are out there. Suspension-wise you guys tend to modify it anyway so that's a moot point...The brake parts can be bought new here: http://brakeperformance.com/brake-dr....php?did=13627 and axles and bearings: http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=92
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
