![]() Join Date: Jan 2002
Fuel lines
There are two line running fron my fuel tank up to the front inside the left side of the frame. One is the fuel line. what is the other? And can I get rid of it..
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
its all about the +6 inches
A return line. Starting in 71, the fuel pump had a return line.
It is a pretty good idea to retain this, you can install a high flow pump to ensure that your bowls never dip low in fuel level, but witht eh return line, the fuel pressure will not increase to the point of blowing the needle off its seat. |
Where does that hook up to. I only have one inlet and one outlet on my fuel pump. I was thinking maybe this went to the old charcoal canister. I am running my exhaust throught the frame and that is where the fuel lines are spliced together. Instead of using a different fuel line on Blazers the front piece is the same as trucks and there is a second piece going back to the tank. I have to replace the whole thing or relocate the splice
