Old 10-29-2014, 08:52 PM   #1
tylerg85
need help with my blinkers
I have a 1986 chevy k10 that when I have the headlights off the driver side blinker works great, but when I turn on my headlights the driver side blinker doesn't work. I replaced the socket and the bulb. the only think I can think of that could cause this problem is a bad ground somewhere. any ideas what could be causing this or where to look for a ground problem? thanks in advance guys.
tylerg85 is offline   Reply With Quote
Old 10-31-2014, 09:00 AM   #2
chengny
chengny's Avatar
Re: need help with my blinkers
Here are the ground points for the front lighting circuits:
Pull the bolts, wire brush the threads and underside of the bolt head. Clean both sides of the wire terminals to bright copper. Use a tap and chase the female threads in the weld nuts that the bolts thread into. Also, clean the frame in the immediate area around the weld nut to white metal.
Reconnect the ground wires and make the bolts up nice and tight. Test the associated circuits. If they are okay, apply a light coat of Rust- Oleum Rust Reformer to the raw metal.
chengny is offline   Reply With Quote
