Old 10-29-2014, 10:38 PM   #1
Tango59
Keeping the original gas cap
Couldn't find an answer in the "Search". I relocated my tank to the rear but I want to keep the gas cap in the original location just for looks... Me and a buddy are trying to figure out how it's gonna go.... I'm sure somebody has done it already....ideas ?
Tango59 is offline   Reply With Quote
Old 10-29-2014, 10:47 PM   #2
leftybass209
leftybass209's Avatar
Re: Keeping the original gas cap
I've seen one that was basically the neck of the tank cut off and it had bracing inside to hold it in place. I think it was rod welded to the inside panel.
leftybass209 is offline   Reply With Quote
Old 10-29-2014, 11:08 PM   #3
Tango59
That's what we were thinking. Haven't found any pics on the internet tho.
Old 10-30-2014, 12:21 AM   #4
boraxman
Keepin an eye out
boraxman's Avatar
Theres a pic somewhere on this site, basically what you do is pull the tank out, leave the grommet, take the gas cap and drill a hole in it...Take a piece of flat steel and cut it to fit on the inside of cab on behind the grommet opposite of the gas cap and drill a hole in it too - using it for a brace. Put the bolt through the cap through the grommet and through the flat steel brace with a nut on the end...Hope that makes sense.
Found the thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=250995
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 10-30-2014, 12:43 AM   #5
71swb4x4
71swb4x4's Avatar
I placed the cap on the grommet, put a long bolt across the back of the grommet inside the cab, and put a wire tie around each gas cap tab and around the bolt. Obviously you don't need to use a bolt, anything longer than the grommet is wide will work.
Edit
Whatever you do make sure the cap won't come off. There is a story on here of some loaning their truck to someone, and that person put several gallons of gas down the old filler tube before they realized it was going all over behind the seat.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-30-2014, 12:45 AM   #6
kitsbeach
kitsbeach's Avatar
Here is what I did.
I wanted to keep the longer neck sticking out so that it would look like stock. The filler neck has a small ridge that prevents it from being pushed in (and if it does get pushed in you will know where to find it). I just put a bolt in it to prevent it from being pulled out. Later on I filled it with construction foam so that nobody would accidentally fill my cab with gas (no pic for that yet).
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
