Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-30-2014, 12:04 AM   #1
65chevysub
65chevysub's Avatar
Oil filter adapter issues
Is there a better type of oil filter adapter than the one from Mr. Gasket? My filter fell off today as the nipple was too far in and even though the filter seem tight, it still fell off. My engine is a 1963 283 that originally had the canister filter. Thanks
65chevysub is offline   Reply With Quote
Old 10-30-2014, 10:48 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Oil filter adapter issues
You should be able to get a factory GM one from a dealer. Other option is to hit up a junk yard and remove a factory one from another engine.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-30-2014, 06:22 PM   #3
65chevysub
65chevysub's Avatar
Thanks Chevy mike. I thought later models had the filter area recessed into the block and thethreaded nipple was threaded into the block? I'll check it out and see about changing out my setup
Old 10-31-2014, 12:29 AM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
I had the same experience with an aftermarket adapter on a 283 back in the 70's. The adapter actually cracked and the filter fell off. I discovered the problem when the rods started knocking. I was really lucky finding a .010 under crank in good shape and a replacement set of matching bearings fixed the damage.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 10-31-2014, 08:22 AM   #5
65chevysub
65chevysub's Avatar
That was lucky. Ayou having any issues with your gauge? Mine reads ok, at first, but when the oil gets warmed up, and I'm stopped, it reads 0, but no knocking or engine noise. When I'm driving, it reads about 40-50psi. Possibly a bad gauge?
Old 11-01-2014, 11:53 PM   #6
Captainfab
60-66 Nut
The factory oil filter adapter/bypass will not work on the '67 and earlier small blocks to convert them to a spin on oil filter.
Old 11-02-2014, 12:03 AM   #7
Captainfab
60-66 Nut
I've been lucky enough that I haven't had to buy one of these adapters,.I have acquired a few from early small blocks that were scrapped. So I did a quick search and came up with these results.
http://www.summitracing.com/search/p...ter%20Adapters
The TansDapt pieces might be better than Mr Gasket, but not by much. Myself I would go with the one from Perma Cool.
Old 11-02-2014, 12:32 AM   #8
65chevysub
65chevysub's Avatar
Thanks Capnfab. Do you think JB Wild would hold the nipple in place? You also answered my curiosity about the bypass as well
Old 11-02-2014, 01:24 AM   #9
Captainfab
60-66 Nut
I have never used JB Weld, but one of the forms of Loctite might work.
Old 11-02-2014, 10:34 AM   #10
65chevysub
65chevysub's Avatar
I w thinking of Loctite as well. I just want the nipple to stop moving so my filter stays on. Thanks
Old 11-03-2014, 12:55 PM   #11
chevy_mike
chevy_mike's Avatar
Guess I missed the year of the block. Doh!
