Windshield washer not staying primed
My windshield washer will not stayed primed. My pump works great & my squirters are clean, but if it sits for a few hours or days it takes forever for it to get fluid back up to the squirters. It seems to have gotten worse since I shortened the supply line, I had way too much extra line coiled up inside the fender well & shortened it thinking it would get fluid up to the squirters quicker. But I guess I wrong about that. Any suggestions besides replacing the original pump with an electric pump?
"Now all I need is a shop to go with my shop vac!" ![]() |
Re: Windshield washer not staying primed
i'd replace the hoses with brand new tight fitting hoses
You didn't say what year, but I'll assume it is under the dash like a 72. The pump manifold that the hoses attach to go bad, even if new. The manifold has the 3 small rubber valves, and if they don't seal, the pump won't pump. Even a brand new one from the parts store may be years old and have dried out valves that don't seal. Every time I think about the pump, I grind my teeth. What a stupid place to put it.
I installed all new hoses & fittings & I still have the problem.
#5 | |
![]() Join Date: May 2010
The easy fix might be to try a cheap check valve out of sight in the supply line between the reservoir and pump. A lot easier than getting to the pump.
Not sure this is the right size or the proper application...does say liquid in the title though. http://www.ebay.com/itm/Hydrogen-HHO...10571a&vxp=mtr Found this by searching ebay motors for "check valve". Lots more in various sizes including some for gas and diesel made of aluminum. http://www.ebay.com/itm/6mm-1-4-Fuel...5f499e&vxp=mtr Last edited by FirstOwner69; 10-30-2014 at 10:02 PM. |
The original pump in my '71 didn't work when I got it so I installed an electric pump under the dash, and it still looses its prime. After the truck has sat for a while and I turn it on it takes at least 5 seconds for the pump to prime the whole system. So with an electric pump it still looses its prime but you don't have to manually prime it because the electric pump is strong enough to do that.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Yep. A cheap check valve will do the trick.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored 1978 Turbo Malibu - Owned since 1986 1987 Grand National Aerocoupe -1 of 1 1988 LeSabre T-Type - Supercharged |
#9 | |
I fitted a one way valve I got from a pet store which is used in fish tanks it was exactly the right size and was only a couple bucks!
"I ain't got no time for side tracks!" 69 R/T Charger 72 C10 Chevrolet 85 302 Jaguar 99 955 Daytona 10 1050 Speed Triple |
