Old 10-30-2014, 01:21 PM   #1
g mcmaine
TRKFRMR1
Booster question
Guys,I am replacing the front power drums on my 68 C20 with a disc setup from a 71 C20.My question is,Can I use the 68 drum/drum booster on the disc/drum setup?Booster on the 71 already gone.
Thanks.
g mcmaine is offline   Reply With Quote
Old 10-30-2014, 04:38 PM   #2
cleszkie
cleszkie's Avatar
Re: Booster question
Yes. But you need to swap out your drum/drum proportioning valve to a disc/drum unit.
cleszkie is offline   Reply With Quote
Old 10-31-2014, 06:03 PM   #3
seth7843
seth7843's Avatar
Yes. The booster will work. Like cleszkie said you need to get a proportioning valve for disc/drum. It also wouldn't be a bad idea to get a 71 master cylinder. The reservoir for the discs is bigger than the one for drums. Your current mc will have two of the same size reservoirs.
seth7843 is offline   Reply With Quote
Old 11-02-2014, 09:50 AM   #4
g mcmaine
TRKFRMR1
Thanks to both of you,I appreciate the info.
Gerald.
