Why are the prices all over the place?
I am going to a 400hp crate 350 from summit racing and I want to go to a new aluminum radiator with an alum schrod and a double fan
I am seeing prices from $150-1500 I count want to have to buy the item twice but also don't want to throw money at something unnecessarily I have a 65 shortbed stepside |
Re: Why are the prices all over the place?
I learned about this one from other members right here on the forum.http://www.speedcooling.com/ I got one for myself (great price) and I am happy with it. I only had to modify my lower mount cradles a bit because the lower tank on the new one is wider. I simply cut my cradels in two and mig welded in an extension. Then scrounged up some extra rubber for cushioning in the cradle. My engine is cool and happy too.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Check these board vendors out. The will make just about whatever you want.
I havent dealt with them but others have. http://67-72chevytrucks.com/vboard/s...d.php?t=591690
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
always Vendors first but if they dont have what you need try CFR Performance I got mine there and its nice...Really good pricing
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
Has anyone tried the setup that Brothers offers? I see they have a 3 row direct replacement with the shroud an and electric fan
on sale right now for under $500. |
I'm leaning towards a champion. ..any feedback on those..
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 |
Go to Champion radiators their site is a pain but an aluminum 2 core for your truck is right around 200, I put one in my old truck with a big block and never saw my gauge go over 190.
AJ |
I have one from Champion, it is a 2 core with 1" cores, it cools my LSx with AC and Texas heat very well.
Also, this is the 2nd one I have had, first one sprung a leak and they replaced it for free!
Who Me?
Look at the tail end of my build thread and you can see my Champion and fan install.
Start at #78 of the thread.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
I went with one from a vendor R&D Fabrication http://www.rndfabrication.com/CrossflowRadiators.html I only ordered it about a week ago so it's not in my hands yet BUT it's guaranteed to cool a stock 454 pulling a 28' travel trailer in our triple digit summers.
just a heads up the 2 row Champion radiators only have 3/4" wide tubes and the 3 & 4 rows are only 5/8" tubes. More tubes = more turbulence & less effective cooling. The smaller tubes speak for themselves. I'm not knocking Champion Radiators, I'm just saying to take a good look at what you need or expect from your new radiator and go what will work for your needs. Another example, I had to replace the radiator on my 02 PT Cruiser a couple of years back. I bought a cheap one from Auto Zone or O'reame's I forgot which. My PT was running hotter than normal this last summer. While doing some routine maintenance I noticed all the lower cooling fins were folded over not allowing any flow through the last 6" of the radiator. All the fin's protected by the A/C condenser were fine the lower non protected fins had no flow. I didn't notice when I put the radiator in but the cooling fins weren't much better than aluminum foil. All I ask is to research (which I'm sure why you made your post) and figure what your needs and future needs are and make your purchase based on that. |
#13 | |
