Old 10-30-2014, 08:32 PM   #1
66herbie
Rear Suspension ??'s 66 LWB
Hey guys, have had my 66 since 05, when i was 15. did a "restoration" if you wanna call it that. quick fixes on some things, paint, wheels. called it good. Anyways, can't seem to find any other info on this as to why, but the rear suspension on my truck has the leaf spring setup off a 4x4, however this is a 2wd truck. Has been in the family since around 1970 and has not been changed over to that by anyone that we know of. my question is did some of these trucks have this as an option on 2wd instead of the trailing arms and coils? It is an original custom, if that makes a differance. Thanks in advance!
66herbie is offline   Reply With Quote
Old 10-30-2014, 10:02 PM   #2
66 C10 383
Re: Rear Suspension ??'s 66 LWB
I didn't see where you stated if you have a Chevy or GMC. From the info I've gained here, "usually" the Chevy's had the trailing arm/coil setup and GMC's had the leaf springs. But either were an option for the other. Meaning you could get the GMC optioned with the coil springs and the Chevy's with the leafs.
There also "might" be differences in the US versions compared to the Canadian versions.
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 10-30-2014, 11:39 PM   #3
66herbie
Ah, makes sense, its a chevy. So it probably was optioned that way then. kind of what I've always thought. Dunno why i never asked on here before. Thanks!
