10-31-2014, 01:19 AM | #1 |
Can't get ignition switch out of dash, bad key
Hey party people!
Just trying to get some stuff done between work and sleep. I attempted to get the ignition switch out but failed. Since last using the truck, the ignition is hard to turn with the key. Plus, the key is in pretty bad shape. In fact, it's impossible to turn to the left. If I can't get the cylinder to turn to ACC, so I can push the release button, what's my next step to remove the damn thing? I'm actually looking to replace the cylinder and put a new bezel on, but maybe a sawzall is the proper tool here. I'll just end up buying a new switch.
'68 C10 SWB '85 K30 Blazer |
10-31-2014, 01:26 AM | #2 |
Re: Can't get ignition switch out of dash, bad key
Man thats a bummer. But I am glad you posted this picture. My ignition switch is loose and needs to be tighten up but was not sure which tool to use.
Where did you get that tool? Thanks |
10-31-2014, 08:56 AM | #3 |
Lots of places
Mine came from Classic Industries but you'll pay for it
10-31-2014, 02:00 PM | #4 |
I wondr if you could drill it and force it to turn.
1967custom |
10-31-2014, 02:12 PM | #5 |
Reach out to LockDoc. Leon can probably help.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
10-31-2014, 02:16 PM | #6 |
Worst case scenario use a cut off wheel and cut the switch assembly at the point where it joins at the spacer in the rear- behind dash. You will end up needing a new switch obviously but sound like it anyway. Try to save the spacer if possible and by doing it this way it will save the bezel as well, plus it wont bend you the dash
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
10-31-2014, 06:25 PM | #7 |
I wouldn't do squat until I talked to Leon - Leon knows locks!
11-01-2014, 08:39 AM | #8 |
The Older Generation
Thanks guys.
Hi Brent, The '67's and SOME '68's don't have an accessory position. The first thing I would do is to snug the bezel back up and spray some penetrating oil (not WD-40) or spray lube into the key hole, then put the key in it and turn it off and on a few times. Turn it all the way both ways & pull the key out and insert it a few times too. Make sure you get enough penetrating oil in it to lube the parts but don't get carried away with it. Then try removing the cylinder following the instructions I posted in the thread below. Let me know if that helps it or not. http://67-72chevytrucks.com/vboard/s...d.php?t=462981 LockDoc
11-01-2014, 03:16 PM | #9 |
I am a Referee of life.
Leon said "Patience Grasshopper"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-01-2014, 03:39 PM | #10 |
i didn;t have a key for mine so i used and air hammer and it pushed it out left bezzel alone
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
11-01-2014, 04:20 PM | #11 |
Found out mine doesn't have ACC. I can feel the button in the OFF position. Pushed it in and turned left. Clicked left but now it's stuck inside. I don't have much pulling power as the key/cylinder is so bad the key comes out at any position. I've been rattling it for a while now. Gave up and am working on running the brake lines. Frustrations have continued cause nothing fits worth a damn, I hate LMC and InLine.
11-01-2014, 06:12 PM | #12 |
Maybe stick a toothpick or sliver of wood in there with the key to jam the key so you can pull the cylinder out?
You can get a new cylinder from the local parts store, BTW... |
11-01-2014, 07:05 PM | #13 | |
Another trick is to use a set of picks like this, or an old angled dental pick if the key won't stay in it. That way you can work it back and forth a little as you pull on it. If you turn it back to the right too far it will re-lock. Don't forget to use the lube.... LockDoc
11-02-2014, 09:20 PM | #14 |
11-02-2014, 10:58 PM | #15 | |
LockDoc
