Old 10-31-2014, 01:38 PM   #1
61K10
61K10's Avatar
I6 & V8 throttle the same?
as the title say's, are the 6 and v8 throttle (the arm the rod from carb) hooks up to the same length? mine seems a little short and my tk was org a 235. here is a pic of mine in the middle.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-31-2014, 02:13 PM   #2
Greg63
Enjoy your truck
Greg63's Avatar
Re: I6 & V8 throttle the same?
The I6 and V8 linkages are different under the hood.
The V8 arm is taller than the I6 arm.
Greg
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 10-31-2014, 02:28 PM   #3
padresag
the arm on the engine side of the bellcrank is of a different length. just get a v8 one
ron
padresag is offline   Reply With Quote
Old 10-31-2014, 03:03 PM   #4
61K10
61K10's Avatar
I bought one for a tri-5 chevy v8 about 1 1/2" longer by looks. mine works but is a little touch-e (quick) thanks for the reply's.
1961 chevy K10
Old 10-31-2014, 04:29 PM   #5
VonDog
VonDog's Avatar
Mine was originally an I6 and the PO put in a sbc. I believe he used the original arm as my pedal is really touchy. Would getting a longer arm make it less touchy?
VonDog is offline   Reply With Quote
Old 10-31-2014, 05:14 PM   #6
padresag
the longer that arm the quicker the response. that means the shorter distance that the pedal travels
ron
Old 11-02-2014, 09:09 PM   #7
lobuck64
I got another arm and cut it drilled two holes and bolted it to six cylinder arm using linkage hole and drilled extra hole also have done same thing using small piece of aluminum has worked great
lobuck64 is offline   Reply With Quote
Old 11-03-2014, 02:30 AM   #8
Kenfuzed
Kenfuzed's Avatar
I just recently made a new linkage rod for my SBC swap and it too seems very touchy with the short l6 style arm. I might try to lengthen the arm as well to see if that makes the throttle action manageable. The geometry of the lever certainly impacts the amount of travel.
If that doesn't work I may need to search for a mid-70s pedal assembly that I saw on someone's 64-66 that worked much better.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 11-03-2014, 02:39 AM   #9
Dismas
I did te mid 70's throttle cable mod, and love it.
Now if I could just eliminate my sticky accel pump, my throttle action would be perfect
Dismas is offline   Reply With Quote
