Old 10-31-2014, 01:54 PM   #1
60_Apache
Question 66 C10 6 Lug Float Disk brake conversion from 90s K1500 pick up
Hello
I'm planing to do a 6 Lug Front disk brake conversion on a 1966 C10.
Is it possible to retain the 1966 C10 Hub rotor and wheel bearing.
Then replace the drum with a 6 Lug Float Disk brake from 90s K1500 as shown.
Bolt circle are the same 6 x 5.5"
Hub Reg on the 1990s K1500 Disk brake is slightly small than The Hub Reg on the 1966 C10. Which can be machined to the correct size.
Has any body done this similar conversion recently?
1966 C10 Pick up Drum with bolt circle 6 x 5.5"
1994 K1500 Pick up
60_Apache is offline   Reply With Quote
conversion, disk brake, float
