Old 10-31-2014, 04:44 PM   #1
GA_TMAC
02 Sensor Voltage via Scan When Sensor is Unplugged
Hi All,
I have an 1987 R10 5.0 with THM400 trans. The ECM appears to be working OK. I can get code 12 and I can disconnect the coolant sensor and it throws the code. My question is (when using Win ALDL) should the scan tool (more properly the ECM) be reporting/seeing any voltage if the 02 sensor is disconnected? IF the O2 sensor is unplugged, should it throw a code? Thanks in advance
GA_TMAC
GA_TMAC is offline   Reply With Quote
Old 11-04-2014, 09:35 PM   #2
GA_TMAC
Re: 02 Sensor Voltage via Scan When Sensor is Unplugged
Please help ... great forum!
Old 11-06-2014, 01:51 AM   #3
rfmaster
rfmaster's Avatar
Originally Posted by GA_TMAC View Post
Hi All,
GA_TMAC
Yes, it should report 0.470volts with O2 sensor disconnected. This is the bias voltage that ECM provides on the purple wire. O2 sensor will swing between 0.2 to 0.9 volts under normal operating conditions. Code 44 and 45 are lean - rich condition codes if O2 sensor is fully operational.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
