Old 10-31-2014, 05:35 PM   #1
Knanthrup
One tire getting hot?
Strange situation, but it appears that I have one tire (drivers side front) that gets very warm after driving. However, the wheel itself does NOT get hot. Also, the passenger side front is still cool. I'm trying to figure out if this is a symptom of a problem... here's why
I actually had that same side tire go completely flat while driving on the freeway. Granted, the tire had many miles and years on it, but it still 'appeared' to be in good physical condition. I could not find any cause for the flat which really bothered me. It was not a slow leak, it went flat very quickly, but didn't appear to "blow out" or at least I didn't hear anything. The tire was VERY hot when I pulled off and felt it.
So I got a new tire to replace that one and now that one is feeling very warm as well. I should really replace the other front tire so they match perfectly, but I'm not sure if a slight mismatch in tires would cause this. If there is a problem, I REALLY don't want the new tire to blow out or go flat like the last one did. Not sure if an alignment could cause this - didn't notice any abnormal wear on the old tires?
Knanthrup is offline   Reply With Quote
Old 10-31-2014, 05:54 PM   #2
cdowns
cdowns's Avatar
Re: One tire getting hot?
have you had the truck professionally aligned??
Old 10-31-2014, 06:02 PM   #3
nzc10
nzc10's Avatar
Check the tire pressure you may have a leaking valve
"I ain't got no time for side tracks!"
69 R/T Charger
72 C10 Chevrolet
85 302 Jaguar
99 955 Daytona
10 1050 Speed Triple
nzc10 is offline   Reply With Quote
Old 11-01-2014, 11:37 AM   #4
Andy4639
Old member
Andy4639's Avatar
Check the brakes to see if they are sticking. Check and make sure they are not rubbing on anything also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
