Old 11-01-2014, 04:23 PM   #1
snow89
How worried should I be?
I usually drive my truck on the weekends. its a 454, when I first start it, after its been sitting for the week, it blows liquid out of the exhaust. the liquid looks like a mix of water and oil. It goes away after it warms up. Does this sound like a serious issue? Thanks
snow89 is offline   Reply With Quote
Old 11-01-2014, 04:28 PM   #2
hamjet
hamjet's Avatar
Re: How worried should I be?
Its probably the cooler weather, condensation. what looks like oil is probably the water mixing with soot in the exhaust pipe..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 11-01-2014, 05:36 PM   #3
Tinkermc
I would not worry unless it happens when it's warm.
Tinkermc is offline   Reply With Quote
Old 11-01-2014, 06:57 PM   #4
basketcase
basketcase's Avatar
I agree that it's more than likely condensation. I see that on my vehicles too. Just be sure to drive it long enough to completely dry out the exhaust system when you do start it.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 11-01-2014, 06:59 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
It can still happen when it is warm out. The water in the exhaust has to get hot enough to turn to vapor you don't see. This is a good indication that you don't have any exhaust leaks, or the condensation would be running out somewhere else.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 11-01-2014, 08:39 PM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: How worried should I be?
Years ago mufflers had pin holes in them for this very thing.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-01-2014, 10:11 PM   #7
snow89
Thanks guys. I appreciate the info.
