Old 11-01-2014, 08:15 PM   #1
Jahloha
Jahloha's Avatar
700R4 Xmember Relocation Question
I removed my member because I have bought the POL xmember and tube engine mounts, but when removing my xmember, I saw the other holes people talk about.
So got me thinking, I have heard of people being able to relocate their existing xmember to accomodate the 700r4 being longer then the th350.
So for those of you who have done the 700r4 swap or have the knowledge help me distinguish how many holes, if any, I would have to drill in order to have the 700r4 fit correctly.
Thanks!
Here it is aligned in stock holes
Name:  Original Placement.jpg
Stock holes, another angle
If I slide the xmember down to where all holes align, here it is
Name:  Shifted to next aligned holes.jpg
Another angle
Name:  Second holes #2.jpg
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 11-01-2014, 08:16 PM   #2
Jahloha
Jahloha's Avatar
Re: 700R4 Xmember Relocation Question
you can see that by shifting it down to where all holes line up, it shifts it roughly 3.5"
-JASON
Old 11-02-2014, 09:33 AM   #3
snipescastle2
snipescastle2's Avatar
Talking Re: 700R4 Xmember Relocation Question
The 700R4 (except the Corvette version) is 30 3/4" overall. The TH350 is 27 11/16" with the 6" tailshaft. TH350's also came with 9" & 12" tailshafts.
do you have a two-piece drive shaft or a one-piece? that will make a difference if you have to cut the driveshaft also. I'm pretty sure you would only have to drill two additional holes, or make a tab bracket to extend the mount attachment point to the cross member.
HTH,
Ben
snipescastle2 is offline   Reply With Quote
Old 11-02-2014, 10:30 AM   #4
Katrina/10
Katrina/10's Avatar
None of the factory holes lined up on mine, although it was close. I removed the brackets that bolt to the top of the frame, and drilled 4 holes in the bottom frame rail, I think it was about 2 inches back. If you can bolt up the trans, that is best way to make sure.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 11-02-2014, 11:14 AM   #5
Jahloha
Jahloha's Avatar
HTH,
Ben
I just finished reading up on the stock xmember being unable to drop the pan unless you notch it. true? not true?
-JASON
Old 11-02-2014, 11:23 AM   #6
Katrina/10
Katrina/10's Avatar
That is true. The factory crossmember covers the rear pan bolt holes completely. I went ahead and used it as is, but it looks like trimming the front edge of the crossmember would allow access to the bolts.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 11-02-2014, 01:06 PM   #7
Z10
Z10's Avatar
I just made this swap this spring on my 72 GMC. I used the factory trans support and existing holes in the frame.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 11-02-2014, 01:12 PM   #8
Katrina/10
Katrina/10's Avatar
I suppose it depends on what the truck originally came with. I changed from 6 cyl/powerglide to 350/700 and no trans crossmember holes lined up. Motor mounts in the forward frame holes.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
