6 lug rotors to 5 Lug rotors?????????????
I just had drop spindles with 6 lug rotors put on my truck. Western spindles. Can I get 5 lug rotors to go on the western spindles? The reason. Someone called me after the drop spindles where installed. He may buy my truck, but he wants 5 lug. Help.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 6 lug rotors to 5 Lug rotors?????????????
I don't have any experience with Western Spindles, but as far as I know all the aftermarket spindles are designed to use '73-'87 rotors. So, yes you should be able to simply change the 6 lug rotors for a set of '73-'87 5 lug C10 rotors.
67-72 parts collector,…
![]() Join Date: Nov 2002
Make sure your 5-lug rotors are the 1.25" wide version and you will be fine.
Want rid of your 6 lug rotors? Pm me
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
