65 front window trim removal
I need to remove without damage thanks for info
Re: 65 front window trim removal
hello if the rubber is old I would just cut the rubber to remove it without damage. i have cut them from the inside,afterwards the w/s pops out easily with the trim that's fits in a channel in the rubber. good luck.
![]() Join Date: May 2007
I just used a utility knife to cut out the old rotten rubber windshield gasket with out any trouble.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
1961 crewcab
as they said just cut the rubber... even if you have a new gasket, it is better to waste the $40 gasket than risk breaking the windshield and/ or bending the trim.
the shop manual says to peel the gasket off the windshield frame from the inside while pushing out on the windshield. the gasket and windshield and trim will come out as a unit. ( I tried this once and wasted a good windshield) IF you can get the gasket and windshield out of the truck, then you pull the gasket off the windshield, and then peel the trim out of the rubber.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Thanks for info
