Old 08-15-2003, 11:50 PM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Removing trailing arms
How hard is it to remove the trailing arms. Need to cut holes for exhaust and it would be alot easier to do if the trailing arms were off. Probably be a good time to replace the bushings.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-16-2003, 12:00 AM   #2
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
If you are interested in replacing the bushings, I have a set, bought them from Chevy duty, the inner sleeve that goes around the bolt and the outer bushing. To see a pic just go to chevyduty.com. They are already boxed to ship, someone else was wanting them but I haven't heard from him in a month or so. They are brand new, I only removed them to take a look at them. Comes with a grease pack and full instructions.
if your interested PM me, and I'll notify the other guy that he took a bit to long to respond. $15 to your door...they run about $17 plus shipping from Chevyduty, let me know. From what I under stand the easiest part about removing the trailing arms is getting under the truck to realize that it is gonna be a lot of hard work...LOL...Just kidding, the rear u bolts are an easy unbolt, don't know about the bushings, though in the instructions it advises using a torch to burn of the old bushings..
-Roger
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 08-16-2003, 03:31 AM   #3
Alexis
Member since 2000
Alexis's Avatar
not hard at all....putting back in is another story. If you don't have a small torch you might want to spend the 12 bucks getting one from a hardware store. It will save you alot of time taking out the old ones.
Alexis is offline   Reply With Quote
Old 08-16-2003, 10:05 AM   #4
Low69CST
to break the bolts loose will be the worst. You'll a big breaker bar, since I don't think theres enough room for an impact in that spot. I'd say your also planning on leaving them attached to the rear end, cuz they are a pain in the a$$ to separate.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 08-16-2003, 12:53 PM   #5
1971 Cheyenne
1971 Cheyenne's Avatar
Wiser words have never been said.
What about using a hydraulic press to push them in and out??? After you torch the bushings, I guess the rubber will be gone and the center sleeve will just come out freely. Then you clean them out, and press the new ones in???? Anyone pressed them in using like a c-clamp?
Thanks!
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 08-16-2003, 10:22 PM   #6
72BLAZERDUDE
I was wondering about that. Think maybe I will leave them attached to the rear end. Will they drop down enough to move out of the wayor will I have to loosen them up in the back
Old 08-16-2003, 10:57 PM   #7
phase_one
I had to replace a rusted trailing arm. It was ease to take off. I did have an impact wrench. Since I took on off I took the other one off also to change the bushings. Burned them with a torch. Burn the hell out of the bushing and the wack them out with a hammer. I had sucess and the greased the new bushings and sleaves and the popped in rather easily. Heck i thought it would have been harder.
11 Surbaban
70 C 10
still in progress
phase_one is offline   Reply With Quote
Old 08-16-2003, 11:12 PM   #8
SWINGSAX68
SWINGSAX68's Avatar
to everyone who asked about the trailing arm bushings, sorry they are sold to 72BLAZERDUDE...
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
